[postgis-tickets] [PostGIS] #3916: winnie very unhappy failing on install
PostGIS trac at osgeo.org
Wed Oct 25 13:47:02 PDT 2017
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 2.5.0
Component:  buildbots  |    Version:  2.4.x
 Keywords:             |
 This might be my fault but hard to say since I upgraded winnie's jenkins
 and walked away.  It's been failing for 2 weeks now.
 With this error on 2.5.
 ---- Making install in liblwgeom
 make[1]: Entering directory '/projects/postgis/branches/2.5/liblwgeom'
 /bin/sh ../libtool --mode=install ../ liblwgeom.la
 "/usr/local/lib/liblwgeom.la"
 libtool: install: ../ .libs/liblwgeom.lai /usr/local/lib/liblwgeom.la
 ../libtool: line 1733: ../: Is a directory
 Makefile:166: recipe for target 'install-liblwgeom' failed
 make[1]: *** [install-liblwgeom] Error 126
 make[1]: Leaving directory '/projects/postgis/branches/2.5/liblwgeom'
 GNUmakefile:16: recipe for target 'install' failed
 make: *** [install] Error 1
 Though the error looks very suspicious doesn't seem to have to do with
 jenkins upgrade.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3916>
