[postgis-tickets] [PostGIS] #3916: winnie very unhappy failing on install
trac at osgeo.org
Wed Oct 25 14:50:36 PDT 2017
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.7
Component: buildbots | Version: 2.4.x
Resolution: | Keywords:
Changes (by robe):
* milestone: PostGIS 2.5.0 => PostGIS 2.2.7
Comment:
this is happening on all the tests on winnie, I suspect this change
r16031
---- Making install in liblwgeom
make[1]: Entering directory '/projects/postgis/branches/2.4/liblwgeom'
/bin/sh ../libtool --mode=install ../ liblwgeom.la
"/usr/local/lib/liblwgeom.la"
libtool: install: ../ .libs/liblwgeom.lai /usr/local/lib/liblwgeom.la
../libtool: line 1733: ../: Is a directory
Makefile:166: recipe for target 'install-liblwgeom' failed
make[1]: *** [install-liblwgeom] Error 126
make[1]: Leaving directory '/projects/postgis/branches/2.4/liblwgeom'
GNUmakefile:16: recipe for target 'install' failed
make: *** [install] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3916#comment:1>
