[postgis-tickets] [PostGIS] #3916: Make install no longer works under mingw64
PostGIS trac at osgeo.org
Thu Oct 26 19:06:12 PDT 2017
  Reporter:  robe       |      Owner:  strk
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.2.7
 Component:  buildbots  |    Version:  2.4.x
Resolution:             |   Keywords:
Comment (by robe):
 better but still not working completely.  I thought it was fixed but then
 realized it doesn't work if I don't have a
 /usr/local/lib folder.  I get this error:
 /bin/sh ../libtool --mode=install /bin/install -c liblwgeom.la
 "/usr/local/lib/liblwgeom.la"
 libtool: install: /bin/install -c .libs/liblwgeom.lai
 /bin/install: cannot create regular file '/usr/local/lib/liblwgeom.la': No
 such file or directory
 Makefile:166: recipe for target 'install-liblwgeom' failed
 make[1]: *** [install-liblwgeom] Error 1
 make[1]: Leaving directory '/projects/postgis/branches/2.5/liblwgeom'
 GNUmakefile:16: recipe for target 'install' failed
 make: *** [install] Error 1
 My generated makefile now has
 INSTALL = /bin/install -c
 Can we disable installing in system it's so annoying.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3916#comment:13>
