[postgis-tickets] [PostGIS] #3916: Make install no longer works under mingw64
PostGIS trac at osgeo.org
Fri Oct 27 22:36:32 PDT 2017
  Reporter:  robe       |      Owner:  strk
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 2.2.7
 Component:  buildbots  |    Version:  2.4.x
Resolution:             |   Keywords:
Comment (by robe):
 Just noticed that debbie's also resolves to
 INSTALL = /usr/bin/install -c
 Anyway to force it to resolve to install-sh instead.  Changing back to
 install-sh correctly creates the annoying /usr/local/  folder which I
 constantly delete cause its f-ing annoying that I have stuff in that
 folder I don't want.  So even better would be to not install in system at
 all :).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3916#comment:14>
