[postgis-tickets] [PostGIS] #3916: Make install no longer works under mingw64
trac at osgeo.org
Mon Oct 30 12:05:16 PDT 2017
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.7
Component: buildbots | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
In [changeset:"16081" 16081]:
#!CommitTicketReference repository="" revision="16081"
cleanup dead paths on winnie's build
add --prefix step to prevent liblwgeom from being installed in /usr/local
References #3916
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3916#comment:21>
