[postgis-tickets] [PostGIS] #3916: Make install no longer works under mingw64
trac at osgeo.org
Mon Oct 30 13:34:37 PDT 2017
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.7
Component: buildbots | Version: 2.4.x
Resolution: | Keywords:
Comment (by robe):
In [changeset:"16083" 16083]:
#!CommitTicketReference repository="" revision="16083"
change back to using @INSTALL@ and put in AC_PROG_INSTALL
so install doesn't go to ../ for insall on mingw
References #3916
References #3912
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3916#comment:22>
