[postgis-tickets] [PostGIS] #3914: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 3051
PostGIS trac at osgeo.org
Tue Oct 31 06:32:37 PDT 2017
  Reporter:  laopsahl  |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.4.2
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:
Comment (by strk):
 I guess the first addition introduces a node, which is not removed by
 removing the edge. Check with QGIS TopoViewer, is very helpful for
 debugging PostGIS Topology.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3914#comment:6>
