[postgis-tickets] [PostGIS] #3914: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 3051
trac at osgeo.org
Tue Oct 31 10:57:33 PDT 2017
Reporter: laopsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.2
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by laopsahl):
Thanks thats correct, when I added ST_RemoveIsoNode('test_snapto', 3),
then the code worked ok.
Is that a bug in ST_RemEdgeNewFace or is it suppose to be done by the code
calling is ST_RemEdgeNewFace as below ?
select DropTopology('test_snapto');
select CreateTopology('test_snapto');
select TopoGeo_addLinestring('test_snapto','LINESTRING(609285.46
6549990.58,609277.63 6549983.87)',0);
select TopoGeo_addLinestring('test_snapto','LINESTRING(609277.63
6549983.87,609281.0371 6549986.79)',0);
select ST_RemEdgeNewFace('test_snapto', 2);
select ST_RemoveIsoNode('test_snapto', 3);
select TopoGeo_addLinestring('test_snapto','LINESTRING(609281.0371
6549986.79,609292 6549984)',2);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3914#comment:7>
