[postgis-tickets] r16681 - Remove Geos 3.4 guards
Raul
raul at rmr.ninja
Thu Aug 2 03:07:16 PDT 2018
Author: algunenano
Date: 2018-08-02 03:07:16 -0700 (Thu, 02 Aug 2018)
New Revision: 16681
trunk/configure.ac
trunk/liblwgeom/cunit/cu_triangulate.c
trunk/regress/Makefile.in
References #4069
Closes #4142
Closes https://github.com/postgis/postgis/pull/284
Modified: trunk/configure.ac
--- trunk/configure.ac 2018-08-01 18:32:50 UTC (rev 16680)
+++ trunk/configure.ac 2018-08-02 10:07:16 UTC (rev 16681)
@@ -1181,9 +1181,6 @@
TOPOLOGY="topology"
AC_MSG_RESULT([TOPOLOGY: Topology support requested])
- if test "$GEOS_NUMERIC_VERSION" -lt 30302; then
- AC_MSG_ERROR([Topology requires GEOS version >= 3.3.2. Use --without-topology or install a newer GEOS.])
- fi
else
AC_MSG_RESULT([TOPOLOGY: Topology support disabled])
fi
Modified: trunk/liblwgeom/cunit/cu_triangulate.c
--- trunk/liblwgeom/cunit/cu_triangulate.c 2018-08-01 18:32:50 UTC (rev 16680)
+++ trunk/liblwgeom/cunit/cu_triangulate.c 2018-08-02 10:07:16 UTC (rev 16681)
@@ -18,7 +18,6 @@
static void test_lwgeom_delaunay_triangulation(void)
-#if POSTGIS_GEOS_VERSION >= 34
LWGEOM *in, *tmp, *out;
char *wkt, *exp_wkt;
@@ -42,8 +41,6 @@
CU_ASSERT_STRING_EQUAL(wkt, exp_wkt);
lwfree(wkt);
-#endif /* POSTGIS_GEOS_VERSION >= 34 */
static void test_lwgeom_voronoi_diagram(void)
Modified: trunk/regress/Makefile.in
--- trunk/regress/Makefile.in 2018-08-01 18:32:50 UTC (rev 16680)
+++ trunk/regress/Makefile.in 2018-08-02 10:07:16 UTC (rev 16681)
@@ -192,35 +192,22 @@
clean \
relate_bnr
+# GEOS-3.4 adds:
+# ST_DelaunayTriangles
+TESTS += \
+ delaunaytriangles
-ifeq ($(shell expr $(POSTGIS_GEOS_VERSION) ">=" 34),1)
- # GEOS-3.4 adds:
- # ST_DelaunayTriangles
- TESTS += \
- delaunaytriangles
-endif
ifeq ($(INTERRUPTTESTS),yes)
# Allow CI servers to configure --with-interrupt-tests
TESTS += \
- interrupt
-ifeq ($(shell expr $(GEOS_NUMERIC_VERSION) ">=" 30403),1)
- TESTS += \
- interrupt_relate
-endif
- # GEOS-3.4 adds:
- TESTS += \
+ interrupt \
+ interrupt_relate \
interrupt_buffer
endif
-endif
ifeq ($(shell expr $(POSTGIS_GEOS_VERSION) ">=" 35),1)
# GEOS-3.5 adds:
# ST_ClipByBox2d, ST_Subdivide, ST_Voronoi
