[postgis-tickets] ERROR: rt_raster_from_hexwkb: Raster HEXWKB input must have an even number of characters
Michael.CTR.Lazlo at faa.gov
Thu Aug 2 09:39:10 PDT 2018
I have created a table loading via raster2psql:
raster2pgsql -a -f Spatial_Grid -F -I -M -T ssa_data -X ssa_data *.tif ssa.TERRAIN_GRID
The tif data comes from http://dwtkns.com/srtm/
I load 98 rows of data using above.
So I need elevation data back if I pass to this data a lat and long.
I initially used query: example
SELECT rid, ST_Value(spatial_grid,1,
ST_GEOMFROMEWKT('SRID=4326;POINT(-79.9616664245329 40.0000000968475)')
) AS ALTITUDE
FROM TERRAIN_GRID;
This returns the right answer BUT these raster warnings make it difficult to work with:
NOTICE: Attempting to get pixel value with out of range raster coordinates:
So I came up with a way to only check the row that the point is actually contained within the row raster first. This eliminates the warnings:
SELECT ST_Value(spatial_grid,1, ST_GEOMFROMEWKT('SRID=4326;POINT(-79.9616664245329 40.0000000968475)')) AS ALTITUDE
FROM TERRAIN_GRID
WHERE ST_Contains(ST_Envelope(spatial_grid),ST_SetSRID(ST_MakePoint(-79.9616664245329, 40.0000000968475),4326));
So rather than have someone running this query say from python and have to put in lat longs in twice I created a function:
create or replace function getAltitude(vLongitude decimal,vLatitude decimal)
returns integer as $$
declare
lAltitude ssa.TERRAIN_GRID.spatial_grid%TYPE;
lPointValue varchar := 'SRID=4326;POINT(' || vLongitude || ' ' || vLatitude || ')';
begin
ST_GEOMFROMEWKT(lPointValue)
INTO lAltitude
FROM TERRAIN_GRID
WHERE ST_Contains(ST_Envelope(spatial_grid),ST_SetSRID(ST_MakePoint(vLongitude, vLatitude),4326));
return lAltitude;
end;
$$ LANGUAGE plpgsql;
This compiles without error, but when I run it, this happens:
SELECT * FROM getAltitude(-79.96166, 40.0000);
CONTEXT: PL/pgSQL function getaltitude(numeric,numeric) line 6 at SQL statement
Now it appears to be caused by something in the predicate (where clause):
I say that because if I change the function to:
declare
begin
INTO lAltitude
FROM TERRAIN_GRID;
return lAltitude;
end;
It executes.
I cannot find any information on this. Any help on this would be appreciated!
URL: <http://lists.osgeo.org/pipermail/postgis-tickets/attachments/20180802/09101ba4/attachment-0001.html>
