[postgis-tickets] [PostGIS] #3914: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 3051
trac at osgeo.org
Tue Aug 7 02:23:43 PDT 2018
Reporter: laopsahl | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: topology | Version: trunk
Resolution: wontfix | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
I'm all confused reading this. Is there anything that can be done here?
strk I'm marking this as a won't fix. Feel free to reopen if you can
actually do anything about it. Sounds like you have no plans to.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3914#comment:13>
