[postgis-tickets] [PostGIS] #3507: topology.relation trigger guard insert/update but no delete
trac at osgeo.org
Tue Aug 7 03:08:20 PDT 2018
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.0
Component: topology | Version: 2.0.x
Resolution: wontfix | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
I checked the relationtrigger function that is called for the
relation_integrity_checks.
It returns error if you try to call against a DELETE event.
I don't see an easy way of checking in before delete anyway.
In the case of delete from relation, you have two problems
1) You have to find all references of the topogeometry in the database to
make sure it is not in use anymore (otherwise your topogeometry is
broken). This can be huge check for each run of before delete. The
performance hit is not worth the problem in my opinion, though I guess we
can do some tests.
2) You can't allow a partial delete of a topogeometry (presumably) - I
suppose merges and so forth might change things
and since you only get one record at a time in the before delete trigger,
not sure how you would be able to check after all deletes that you are not
left with a partial topogeometry.
That said I think this problem is unsolvable with triggers. You need to
change the management functions to accomodate.
I'm dismissing this as a wontfix.
strk if you have other thoughts, feel free to reopen.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3507#comment:4>
