[postgis-tickets] [PostGIS] #4104: PostGIS 2.4.4 rt_gdalwrap test fails with GDAL 2.3.0 & PROJ 5.1.0 on Debian unstable
trac at osgeo.org
Sat Aug 11 01:14:03 PDT 2018
unstable
Reporter: Bas Couwenberg | Owner: Bborie Park
Type: patch | Status: new
Priority: blocker | Milestone: PostGIS 2.5.0
Component: raster | Version: 2.4.x
Resolution: | Keywords:
Comment (by Bas Couwenberg):
The changes Even mentioned where included as a patch in the proj (5.0.1-2)
Debian package, the 5.1.0-rc1 upstream release was the first release to
include the changes in proj itself.
The recent development of PROJ has changed coordinate precision quite a
bit, many test cases in other projects needed to be adapted to not expect
the exact same output as with PROJ 4.x. This seems to be another case like
that.
Kristian Evers <kreve at sdfe.dk> should be able to give an authoritative
answer about what changed in PROJ 5.x to cause this issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4104#comment:11>
