[postgis-tickets] [PostGIS] #4148: Reproducible build date in generated SQL files
PostGIS trac at osgeo.org
Tue Aug 14 01:08:12 PDT 2018
  Reporter:  myon         |      Owner:  Algunenano
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 2.5.0
 Component:  postgis      |    Version:  trunk
Resolution:  fixed        |   Keywords:
Changes (by Raul Marin):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16693" 16693]:
 #!CommitTicketReference repository="" revision="16693"
 Enable deterministic builds
 Honor SOURCE_DATE_EPOCH variable if present to enable reproducible builds
 Patch by Christoph Berg <myon -at- debian.org>
 Closes #4147
 Closes #4148
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4148#comment:3>
