[postgis-tickets] [PostGIS] #4149: MVT: Be able to tweak simplification in St_AsMVTGeom
trac at osgeo.org
Thu Aug 16 01:02:49 PDT 2018
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
In some situations you want a big extent (e.g. 4096) to represent the
geometries in a MVT with precision for the current zoom and, until the
request arrives, to temporarily render the next zoom level too, but you
don't want the big tile size that having the geometry ready for 4 zoom
levels implies since you aren't skipping zoom levels (a.k.a. overzooming).
For those cases it's interesting to have the possibility of simplifying
the geometry for a zoom level but keep the main extent to a higher
precision. For example, if you use a 4096 extent for the layer and 512 for
simplification, any points falling inside the same 512 grid can be
considered duplicated, but the final points keep the 4096 precision.
For these use cases what I'm currently doing is simplifying
(`ST_Simplify(ST_RemoveRepeatedPoints(${geomColumn}, ${tol}), ${tol},
true`)) the geometry before entering St_AsMVTGeom. This works but it
means that there are 2 simplification processes going on, the external and
the (now unnecessary) internal.
I see 2 valid options to handle this:
- Add the simplify_extent option to St_AsMVTGeom so the simplification
process and the final snapping can be detached. This would probably be the
option with the best performance.
- Add the option of disabling the simplification process in St_AsMVTGeom
and keep only the external simplification. This is the most future safe
option: if you can disable simplification and add you own, you are able
not only to change tolerance levels but also change simplification
functions (ST_SimplifyPreserveTopology instead of St_Simplify for
example).
There is also the option of adding some kind of hook to the St_AsMVTGeom
to set the simplification functions on the fly, but I feel that that's
just too much complexity.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4149>
