[postgis-tickets] [PostGIS] #4151: ST_3DDwithin Errors on memcmp with pt_in_ring_3d
trac at osgeo.org
Thu Aug 16 05:24:11 PDT 2018
Reporter: tilt | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Keywords: |
The following query:
SELECT
ST_3DDwithin(ST_GeometryFromText('POLYGON Z ((
238122.872000001 576633.508999999 5.98677038142003,
238122.872 576633.509 5.98677038052055,
238121.623809392 576634.389879555 4.95792405791038,
238120.252000002 576635.357999998 3.82718245716979,
238120.252 576635.358 3.82718245541562,
238121.873 576637.738 3.8333125996467,
238121.873000001 576637.737999999 3.83331260027449,
238124.460390651 576635.62447975 6.0745417745131,
238122.991788134 576633.427399075 6.08439985368325,
238122.872000001 576633.508999999 5.98677038142796))
ST_GeometryFromText('POINT Z (238123 576634 0)')
,0.1)
results in:
ERROR: pt_in_ring_3d: V[n] != V[0] (238123 576634 5.98677!= 238123 576634
5.98677)
Likely this is due to a rounding error and happening in:
https://github.com/postgis/postgis/blob/svn-
trunk/liblwgeom/measures3d.c#L1249
The polygon obviously is not a very nice one (with vertices almost on top
of each other) but it is valid. I tried the folowing workarounds: \\
ST_RemoveRepeatedPoints 0.1\\
ST_SnapToGrid 0.1\\
manually cleaning the polygon\\
Only the last option worked so I suspect the problem is in the precision
of the Z-value, since the other two only deal with 2D coordinates.
Running on:
POSTGIS="2.5.0rc1dev r16693" [EXTENSION] PGSQL="100"
GEOS="3.7.0beta2-CAPI-1.11.0 e7d54545" SFCGAL="1.3.5" PROJ="Rel. 5.1.0,
June 1st, 2018" GDAL="GDAL 2.4.0dev-3ea4d4ed14-dirty, released 2018/07/09"
LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.2.1" (core procs from
"2.5.0beta2dev r16638" need upgrade) RASTER (raster procs from
"2.5.0beta2dev r16638" need upgrade) (sfcgal procs from "2.5.0beta1dev
r16609" need upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4151>
