[postgis-tickets] [PostGIS] #4144: When ANALYZE a table that contains certains values on a geometry field, PostgreSQL crash
trac at osgeo.org
Tue Aug 21 06:15:17 PDT 2018
PostgreSQL crash
Reporter: zancos | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by komzpa):
This sounds like there is a cast to 32bit float in histogram build.
FLT_MAX = 3.402823e+38
Out of curiosity, what is the data with this value? I expect that no
normal projection will store such value on surface of the planet.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4144#comment:8>
