[postgis-tickets] [PostGIS] #4138: PostGIS 2.5.0beta1 fails tests on MIPS64EL
trac at osgeo.org
Thu Aug 23 07:42:22 PDT 2018
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by pramsey):
In [changeset:"16703" 16703]:
#!CommitTicketReference repository="" revision="16703"
Generate nan() explicitly with a zeroed out area, does this fix mix WKB
generation of POINT EMPTY? References #4138
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4138#comment:3>
