[postgis-tickets] [PostGIS] #4159: ST_Distance failing with a geography and a point with specific values
PostGIS trac at osgeo.org
Mon Aug 27 04:34:48 PDT 2018
  Reporter:  GustavoAcid  |      Owner:  pramsey
      Type:  defect       |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS PostgreSQL
 Component:  postgis      |    Version:  2.2.x
Resolution:               |   Keywords:  ST_Distance
Comment (by GustavoAcid):
 Replying to [comment:1 komzpa]:
 > Can you share WKB of both geographies?
 I'm kind of new with Spatial Data, how can I retrieve the WKB of both
 geographies?
 > Is 242 km an incorrect result? It sounds like the country-scale
 distance.
 Yes, it is incorrect. The point is in the center of the first Geography.
 If I do the same query with (-3.676523~~3~~, 40.5036783) the result is 0
 as expected.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4159#comment:2>
