[postgis-tickets] [PostGIS] #4163: ST_AsMVT: Resource leak (was: ST_AsMVT: Resource leak under parallel plans)
trac at osgeo.org
Tue Aug 28 09:34:59 PDT 2018
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 2.5.0
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by Algunenano):
After investigating further I've discovered that this leak isn't caused by
parallel plans, it just turned out to appear in the same tests where I get
those plans.
The issue is in `mvt_agg_transfn` as it parses the columns `if
(layer->n_features == 0)` which, in theory, should be only once.
The problem comes when the first (or first N) row has a NULL geometry
since that will go through the transformation without increasing
`layer->n_features`.
In 2.4 this only meant unnecessary work, but in 2.5+ it means allocating
memory again and leaking the resources from the previous call.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4163#comment:1>
