[postgis-tickets] r17095 - Remove support for Postgres < 9.5.
Darafei
komzpa at gmail.com
Mon Dec 3 01:03:58 PST 2018
Author: komzpa
Date: 2018-12-03 01:03:57 -0800 (Mon, 03 Dec 2018)
New Revision: 17095
trunk/NEWS
trunk/configure.ac
trunk/libpgcommon/lwgeom_pg.h
trunk/postgis/Makefile.in
trunk/postgis/geography_brin.sql.in
trunk/postgis/gserialized_estimate.c
trunk/postgis/gserialized_gist_2d.c
trunk/postgis/gserialized_gist_nd.c
trunk/postgis/lwgeom_functions_basic.c
trunk/postgis/lwgeom_geos.c
trunk/postgis/lwgeom_inout.c
trunk/postgis/mvt.c
trunk/postgis/postgis.sql.in
trunk/raster/rt_pg/rtpg_band_properties.c
trunk/raster/rt_pg/rtpg_geometry.c
trunk/raster/rt_pg/rtpg_mapalgebra.c
trunk/regress/core/Makefile.in
Closes https://github.com/postgis/postgis/pull/349
Closes #4229
Modified: trunk/NEWS
--- trunk/NEWS 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/NEWS 2018-12-03 09:03:57 UTC (rev 17095)
@@ -8,7 +8,8 @@
if you need the old behavior (Regina Obe)
- #4230, ND box operators (overlaps, contains, within, equals) now don't look on
dimentions that aren't present in both operands.
- Please REINDEX your ND indexes after upgrade.
+ Please REINDEX your ND indexes after upgrade. (Darafei Praliaskouski)
+ - #4229, Dropped support for PostgreSQL < 9.5. (Darafei Praliaskouski)
* New Features *
- #2902, postgis_geos_noop (Sandro Santilli)
Modified: trunk/configure.ac
--- trunk/configure.ac 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/configure.ac 2018-12-03 09:03:57 UTC (rev 17095)
@@ -468,11 +468,6 @@
AC_MSG_ERROR([PostGIS requires PostgreSQL >= 9.5])
fi
- HAVE_BRIN=no
- if test $POSTGIS_PGSQL_VERSION -gt 94; then
- HAVE_BRIN=yes
- fi
HAVE_SPGIST=no
if test $POSTGIS_PGSQL_VERSION -gt 100; then
HAVE_SPGIST=yes
@@ -546,7 +541,6 @@
AC_DEFINE_UNQUOTED([POSTGIS_PGSQL_VERSION], [$POSTGIS_PGSQL_VERSION], [PostgreSQL server version])
AC_SUBST([POSTGIS_PGSQL_VERSION])
- AC_SUBST([HAVE_BRIN])
AC_SUBST([HAVE_SPGIST])
fi dnl LIBLWGEOM_ONLY != no
Modified: trunk/libpgcommon/lwgeom_pg.h
--- trunk/libpgcommon/lwgeom_pg.h 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/libpgcommon/lwgeom_pg.h 2018-12-03 09:03:57 UTC (rev 17095)
@@ -124,14 +124,6 @@
int gserialized_datum_get_gbox_p(Datum gsdatum, GBOX *gbox);
- * For PostgreSQL >= 8.5 redefine the STATRELATT macro to its
- * new value of STATRELATTINH
-#if POSTGIS_PGSQL_VERSION >= 85
- #define STATRELATT STATRELATTINH
-#endif
/* PG-exposed */
Datum BOX2D_same(PG_FUNCTION_ARGS);
Datum BOX2D_overlap(PG_FUNCTION_ARGS);
@@ -151,34 +143,32 @@
Datum LWGEOM_same(PG_FUNCTION_ARGS);
/** needed for sp-gist support PostgreSQL 11+ **/
-//#if POSTGIS_PGSQL_VERSION > 100
- Datum BOX3D_construct(PG_FUNCTION_ARGS);
+Datum BOX3D_construct(PG_FUNCTION_ARGS);
- Datum LWGEOM_to_BOX2DF(PG_FUNCTION_ARGS);
- Datum LWGEOM_to_BOX3D(PG_FUNCTION_ARGS);
- Datum BOX3D_contains(PG_FUNCTION_ARGS);
- Datum BOX3D_contained(PG_FUNCTION_ARGS);
- Datum BOX3D_overlaps(PG_FUNCTION_ARGS);
- Datum BOX3D_same(PG_FUNCTION_ARGS);
- Datum BOX3D_left(PG_FUNCTION_ARGS);
- Datum BOX3D_overleft(PG_FUNCTION_ARGS);
- Datum BOX3D_right(PG_FUNCTION_ARGS) ;
- Datum BOX3D_overright(PG_FUNCTION_ARGS);
- Datum BOX3D_below(PG_FUNCTION_ARGS);
- Datum BOX3D_overbelow(PG_FUNCTION_ARGS);
- Datum BOX3D_above(PG_FUNCTION_ARGS);
- Datum BOX3D_overabove(PG_FUNCTION_ARGS);
- Datum BOX3D_front(PG_FUNCTION_ARGS);
- Datum BOX3D_overfront(PG_FUNCTION_ARGS);
- Datum BOX3D_back(PG_FUNCTION_ARGS);
- Datum BOX3D_overback(PG_FUNCTION_ARGS);
- Datum BOX3D_distance(PG_FUNCTION_ARGS);
+Datum LWGEOM_to_BOX2DF(PG_FUNCTION_ARGS);
+Datum LWGEOM_to_BOX3D(PG_FUNCTION_ARGS);
+Datum BOX3D_contains(PG_FUNCTION_ARGS);
+Datum BOX3D_contained(PG_FUNCTION_ARGS);
+Datum BOX3D_overlaps(PG_FUNCTION_ARGS);
+Datum BOX3D_same(PG_FUNCTION_ARGS);
+Datum BOX3D_left(PG_FUNCTION_ARGS);
+Datum BOX3D_overleft(PG_FUNCTION_ARGS);
+Datum BOX3D_right(PG_FUNCTION_ARGS);
+Datum BOX3D_overright(PG_FUNCTION_ARGS);
+Datum BOX3D_below(PG_FUNCTION_ARGS);
+Datum BOX3D_overbelow(PG_FUNCTION_ARGS);
+Datum BOX3D_above(PG_FUNCTION_ARGS);
+Datum BOX3D_overabove(PG_FUNCTION_ARGS);
+Datum BOX3D_front(PG_FUNCTION_ARGS);
+Datum BOX3D_overfront(PG_FUNCTION_ARGS);
+Datum BOX3D_back(PG_FUNCTION_ARGS);
+Datum BOX3D_overback(PG_FUNCTION_ARGS);
+Datum BOX3D_distance(PG_FUNCTION_ARGS);
- #define DatumGetBox3DP(X) ((BOX3D *) DatumGetPointer(X))
- #define Box3DPGetDatum(X) PointerGetDatum(X)
- #define PG_GETARG_BOX3D_P(n) DatumGetBox3DP(PG_GETARG_DATUM(n))
- #define PG_RETURN_BOX3D_P(x) return Box3DPGetDatum(x)
-//#endif
+#define DatumGetBox3DP(X) ((BOX3D *)DatumGetPointer(X))
+#define Box3DPGetDatum(X) PointerGetDatum(X)
+#define PG_GETARG_BOX3D_P(n) DatumGetBox3DP(PG_GETARG_DATUM(n))
+#define PG_RETURN_BOX3D_P(x) return Box3DPGetDatum(x)
Datum LWGEOM_force_2d(PG_FUNCTION_ARGS);
Datum LWGEOM_force_3dm(PG_FUNCTION_ARGS);
Modified: trunk/postgis/Makefile.in
--- trunk/postgis/Makefile.in 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/postgis/Makefile.in 2018-12-03 09:03:57 UTC (rev 17095)
@@ -32,10 +32,6 @@
MODULE_big=postgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
endif
-ifeq (@HAVE_BRIN@,yes)
-BRIN_OBJ= brin_2d.o brin_nd.o brin_common.o
-endif
# Files to be copied to the contrib/ directory
SQL_built=postgis.sql postgis_for_extension.sql uninstall_postgis.sql postgis_upgrade.sql postgis_upgrade_for_extension.sql postgis_proc_set_search_path.sql legacy.sql uninstall_legacy.sql legacy_minimal.sql legacy_gist.sql
DATA=../spatial_ref_sys.sql
@@ -56,10 +52,6 @@
SQL_OBJS=$(SQL_objs)
endif
-endif
ifeq (@HAVE_SPGIST@,yes)
SPGIST_OBJ= gserialized_spgist_2d.o gserialized_spgist_3d.o gserialized_spgist_nd.o
endif
@@ -109,7 +101,9 @@
gserialized_gist_2d.o \
gserialized_gist_nd.o \
$(SPGIST_OBJ) \
- $(BRIN_OBJ) \
+ brin_2d.o \
+ brin_nd.o \
+ brin_common.o \
gserialized_estimate.o \
geography_inout.o \
geography_btree.o \
Modified: trunk/postgis/geography_brin.sql.in
--- trunk/postgis/geography_brin.sql.in 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/postgis/geography_brin.sql.in 2018-12-03 09:03:57 UTC (rev 17095)
@@ -1,4 +1,3 @@
-#if POSTGIS_PGSQL_VERSION > 94
-- BRIN support for geographies --
@@ -72,5 +71,3 @@
OPERATOR 3 &&(gidx, geography),
OPERATOR 3 &&(gidx, gidx),
STORAGE gidx;
-#endif
Modified: trunk/postgis/gserialized_estimate.c
--- trunk/postgis/gserialized_estimate.c 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/postgis/gserialized_estimate.c 2018-12-03 09:03:57 UTC (rev 17095)
@@ -102,9 +102,7 @@
#include "../postgis_config.h"
-#if POSTGIS_PGSQL_VERSION >= 93
- #include "access/htup_details.h"
-#endif
+#include "access/htup_details.h"
#include "stringbuffer.h"
#include "liblwgeom.h"
@@ -147,15 +145,15 @@
Datum geometry_estimated_extent(PG_FUNCTION_ARGS);
-* Assign a number to the n-dimensional statistics kind
-* tgl suggested:
-* 1-100: reserved for assignment by the core Postgres project
-* 100-199: reserved for assignment by PostGIS
-* 200-9999: reserved for other globally-known stats kinds
-* 10000-32767: reserved for private site-local use
+ * Assign a number to the n-dimensional statistics kind
+ * tgl suggested:
+ * 1-100: reserved for assignment by the core Postgres project
+ * 100-199: reserved for assignment by PostGIS
+ * 200-9999: reserved for other globally-known stats kinds
+ * 10000-32767: reserved for private site-local use
#define STATISTIC_KIND_ND 102
#define STATISTIC_KIND_2D 103
#define STATISTIC_SLOT_ND 0
Modified: trunk/postgis/gserialized_gist_2d.c
--- trunk/postgis/gserialized_gist_2d.c 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/postgis/gserialized_gist_2d.c 2018-12-03 09:03:57 UTC (rev 17095)
@@ -108,8 +108,6 @@
Datum gserialized_overbelow_2d(PG_FUNCTION_ARGS);
Datum gserialized_distance_box_2d(PG_FUNCTION_ARGS);
Datum gserialized_distance_centroid_2d(PG_FUNCTION_ARGS);
Datum gserialized_contains_box2df_geom_2d(PG_FUNCTION_ARGS);
Datum gserialized_contains_box2df_box2df_2d(PG_FUNCTION_ARGS);
Datum gserialized_within_box2df_geom_2d(PG_FUNCTION_ARGS);
@@ -116,7 +114,6 @@
Datum gserialized_within_box2df_box2df_2d(PG_FUNCTION_ARGS);
Datum gserialized_overlaps_box2df_geom_2d(PG_FUNCTION_ARGS);
Datum gserialized_overlaps_box2df_box2df_2d(PG_FUNCTION_ARGS);
-#endif
** true/false test function type
@@ -492,83 +489,6 @@
return sqrt((a_x - b_x) * (a_x - b_x) + (a_y - b_y) * (a_y - b_y));
-#if POSTGIS_PGSQL_VERSION < 95
-* Calculate the The node_box_edge->query_centroid distance
-* between the boxes.
-static double box2df_distance_node_centroid(const BOX2DF *node, const BOX2DF *query)
- BOX2DF q;
- double qx, qy;
- double d = 0.0;
- /* Turn query into point */
- q.xmin = q.xmax = (query->xmin + query->xmax) / 2.0;
- q.ymin = q.ymax = (query->ymin + query->ymax) / 2.0;
- qx = q.xmin;
- qy = q.ymin;
- /* Check for overlap */
- if ( box2df_overlaps(node, &q) == LW_TRUE )
- return 0.0;
- /* Above or below */
- if ( qx >= node->xmin && qx <= node->xmax )
- if( qy > node->ymax )
- d = qy - node->ymax;
- else if ( qy < node->ymin )
- d = node->ymin - qy;
- return d;
- /* Left or right */
- else if ( qy >= node->ymin && qy <= node->ymax )
- if ( qx > node->xmax )
- d = qx - node->xmax;
- else if ( qx < node->xmin )
- d = node->xmin - qx;
- return d;
- /* Corner quadrants */
- else
- /* below/left of xmin/ymin */
- if ( qx < node->xmin && qy < node->ymin )
- d = (node->xmin - qx) * (node->xmin - qx) +
- (node->ymin - qy) * (node->ymin - qy);
- /* above/left of xmin/ymax */
- else if ( qx < node->xmin && qy > node->ymax )
- (node->ymax - qy) * (node->ymax - qy);
- /* above/right of xmax/ymax */
- else if ( qx > node->xmax && qy > node->ymax )
- d = (node->xmax - qx) * (node->xmax - qx) +
- /* below/right of xmax/ymin */
- else if ( qx > node->xmin && qy < node->ymin )
- else
- /*ERROR*/
- elog(ERROR, "%s: reached unreachable code", __func__);
- return sqrt(d);
-#endif
/* Quick distance function */
static inline double pt_distance(double ax, double ay, double bx, double by)
@@ -707,7 +627,6 @@
return LW_FALSE;
static int
gserialized_datum_predicate_box2df_geom_2d(const BOX2DF *br1, Datum gs2, box2df_predicate predicate)
@@ -784,7 +703,6 @@
PG_RETURN_BOOL(false);
-#endif
* GiST 2-D Index Operator Functions
@@ -1254,9 +1172,7 @@
BOX2DF *entry_box;
StrategyNumber strategy = (StrategyNumber) PG_GETARG_UINT16(2);
double distance;
-#if POSTGIS_PGSQL_VERSION >= 95
bool *recheck = (bool *) PG_GETARG_POINTER(4);
-#endif
POSTGIS_DEBUG(4, "[GIST] 'distance' function called");
@@ -1277,8 +1193,6 @@
/* Get the entry box */
entry_box = (BOX2DF*)DatumGetPointer(entry->key);
/* Box-style distance test */
if ( strategy == 14 ) /* operator <#> */
@@ -1300,27 +1214,7 @@
PG_RETURN_NULL();
-#else
- /* Box-style distance test */
- if ( strategy == 14 )
- distance = (double)box2df_distance(entry_box, &query_box);
- PG_RETURN_FLOAT8(distance);
- /* Treat leaf node tests different from internal nodes */
- if (GIST_LEAF(entry))
- /* Calculate distance to leaves */
- distance = (double)box2df_distance_leaf_centroid(entry_box, &query_box);
- else
- /* Calculate distance for internal nodes */
- distance = (double)box2df_distance_node_centroid(entry_box, &query_box);
-#endif
Modified: trunk/postgis/gserialized_gist_nd.c
--- trunk/postgis/gserialized_gist_nd.c 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/postgis/gserialized_gist_nd.c 2018-12-03 09:03:57 UTC (rev 17095)
@@ -774,7 +774,6 @@
** '~~' and operator function. Based on a GIDX and a serialized return true if
** the first is contained by the second.
@@ -802,7 +801,6 @@
-#endif
** '@@' and operator function. Based on two serialized return true if
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/postgis/lwgeom_functions_basic.c 2018-12-03 09:03:57 UTC (rev 17095)
@@ -1244,11 +1244,7 @@
count = 0;
outtype = 0;
iterator = array_create_iterator(array, 0, NULL);
-#else
- iterator = array_create_iterator(array, 0);
-#endif
while (array_iterate(iterator, &value, &isnull))
@@ -1420,11 +1416,7 @@
geoms = palloc(sizeof(LWGEOM *) * nelems);
ngeoms = 0;
-#else
-#endif
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/postgis/lwgeom_geos.c 2018-12-03 09:03:57 UTC (rev 17095)
@@ -372,12 +372,8 @@
if ( nelems == 0 ) PG_RETURN_NULL();
/* Quick scan for nulls */
-#else
-#endif
- while( array_iterate(iterator, &value, &isnull) )
+ while (array_iterate(iterator, &value, &isnull))
/* Skip null array items */
if (isnull) continue;
@@ -412,12 +408,8 @@
** We need to convert the array of GSERIALIZED into a GEOS collection.
** First make an array of GEOS geometries.
-#else
-#endif
GSERIALIZED *gser_in;
@@ -2673,19 +2665,11 @@
Datum value;
bool isnull;
uint32_t nelems_not_null = 0;
-#else
-#endif
while(array_iterate(iterator, &value, &isnull) )
if (!isnull)
nelems_not_null++;
array_free_iterator(iterator);
return nelems_not_null;
@@ -2702,42 +2686,36 @@
LWGEOM** lw_geoms = palloc(nelems * sizeof(LWGEOM*));
-#else
-#endif
- while(array_iterate(iterator, &value, &isnull))
- GSERIALIZED *geom = (GSERIALIZED*) DatumGetPointer(value);
+ GSERIALIZED *geom = (GSERIALIZED *)DatumGetPointer(value);
- if (isnull)
- continue;
+ if (isnull)
+ continue;
- *is3d = *is3d || gserialized_has_z(geom);
+ *is3d = *is3d || gserialized_has_z(geom);
- lw_geoms[i] = lwgeom_from_gserialized(geom);
- if (!lw_geoms[i]) /* error in creation */
- lwpgerror("Geometry deserializing geometry");
- return NULL;
- if (!gotsrid)
- gotsrid = true;
- *srid = gserialized_get_srid(geom);
- else if (*srid != gserialized_get_srid(geom))
- error_if_srid_mismatch(*srid, gserialized_get_srid(geom));
- return NULL;
+ lw_geoms[i] = lwgeom_from_gserialized(geom);
+ if (!lw_geoms[i]) /* error in creation */
+ lwpgerror("Geometry deserializing geometry");
+ return NULL;
+ if (!gotsrid)
+ gotsrid = true;
+ *srid = gserialized_get_srid(geom);
+ else if (*srid != gserialized_get_srid(geom))
+ error_if_srid_mismatch(*srid, gserialized_get_srid(geom));
+ return NULL;
- i++;
+ i++;
return lw_geoms;
@@ -2753,11 +2731,7 @@
GEOSGeometry** geos_geoms = palloc(nelems * sizeof(GEOSGeometry*));
-#else
-#endif
@@ -2764,9 +2738,7 @@
if (isnull)
continue;
Modified: trunk/postgis/lwgeom_inout.c
--- trunk/postgis/lwgeom_inout.c 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/postgis/lwgeom_inout.c 2018-12-03 09:03:57 UTC (rev 17095)
@@ -560,13 +560,8 @@
/* Loop through array and build a collection of geometry and */
/* a simple array of ids. If either side is NULL, skip it */
iter_geoms = array_create_iterator(arr_geoms, 0, NULL);
iter_ids = array_create_iterator(arr_ids, 0, NULL);
-#else
- iter_geoms = array_create_iterator(arr_geoms, 0);
- iter_ids = array_create_iterator(arr_ids, 0);
-#endif
while( array_iterate(iter_geoms, &val_geom, &null_geom) &&
array_iterate(iter_ids, &val_id, &null_id) )
Modified: trunk/postgis/mvt.c
--- trunk/postgis/mvt.c 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/postgis/mvt.c 2018-12-03 09:03:57 UTC (rev 17095)
@@ -28,10 +28,7 @@
#include "pgsql_compat.h"
#ifdef HAVE_LIBPROTOBUF
-#if POSTGIS_PGSQL_VERSION >= 94
#include "utils/jsonb.h"
-#endif
#if POSTGIS_PGSQL_VERSION < 110
/* See trac ticket #3867 */
@@ -339,13 +336,12 @@
char *tkey = TupleDescAttr(ctx->column_cache.tupdesc, i)->attname.data;
ctx->column_cache.column_oid[i] = typoid;
if (typoid == JSONBOID)
ctx->column_cache.column_keys_index[i] = UINT32_MAX;
continue;
-#endif
if (ctx->geom_name == NULL)
@@ -726,7 +722,6 @@
k = cc.column_keys_index[i];
typoid = cc.column_oid[i];
if (k == UINT32_MAX && typoid != JSONBOID)
elog(ERROR, "parse_values: unexpectedly could not find parsed key name '%s'", key);
@@ -734,10 +729,6 @@
tags = parse_jsonb(ctx, DatumGetJsonbP(datum), tags);
continue;
-#else
- if (k == UINT32_MAX)
- elog(ERROR, "parse_values: unexpectedly could not find parsed key name '%s'", key);
-#endif
switch (typoid)
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/postgis/postgis.sql.in 2018-12-03 09:03:57 UTC (rev 17095)
@@ -578,11 +578,7 @@
-- Availability: 2.0.0
CREATE OR REPLACE FUNCTION geometry_distance_centroid(geom1 geometry, geom2 geometry)
RETURNS float8
AS 'MODULE_PATHNAME', 'ST_Distance'
-#else
- AS 'MODULE_PATHNAME', 'gserialized_distance_centroid_2d'
-#endif
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
Modified: trunk/raster/rt_pg/rtpg_band_properties.c
--- trunk/raster/rt_pg/rtpg_band_properties.c 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/raster/rt_pg/rtpg_band_properties.c 2018-12-03 09:03:57 UTC (rev 17095)
@@ -736,19 +736,21 @@
nulls[5] = TRUE;
- if (bmd2[call_cntr].filesize) {
+ if (bmd2[call_cntr].filesize)
#if POSTGIS_PGSQL_VERSION > 95
- values[6] = UInt64GetDatum(bmd2[call_cntr].filesize);
- values[7] = UInt64GetDatum(bmd2[call_cntr].timestamp);
+ values[6] = UInt64GetDatum(bmd2[call_cntr].filesize);
+ values[7] = UInt64GetDatum(bmd2[call_cntr].timestamp);
#else /* POSTGIS_PGSQL_VERSION <= 95 */
- values[6] = Int64GetDatum(bmd2[call_cntr].filesize);
- values[7] = Int64GetDatum(bmd2[call_cntr].timestamp);
+ values[6] = Int64GetDatum(bmd2[call_cntr].filesize);
+ values[7] = Int64GetDatum(bmd2[call_cntr].timestamp);
#endif
- else {
- nulls[6] = TRUE;
- nulls[7] = TRUE;
+ else
+ nulls[6] = TRUE;
+ nulls[7] = TRUE;
/* build a tuple */
tuple = heap_form_tuple(tupdesc, values, nulls);
Modified: trunk/raster/rt_pg/rtpg_geometry.c
--- trunk/raster/rt_pg/rtpg_geometry.c 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/raster/rt_pg/rtpg_geometry.c 2018-12-03 09:03:57 UTC (rev 17095)
@@ -37,10 +37,7 @@
#include "../../postgis_config.h"
-#if POSTGIS_PGSQL_VERSION > 92
#include "access/htup_details.h" /* for heap_form_tuple() */
-#endif
#include "lwgeom_pg.h"
#include "rtpostgis.h"
Modified: trunk/raster/rt_pg/rtpg_mapalgebra.c
--- trunk/raster/rt_pg/rtpg_mapalgebra.c 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/raster/rt_pg/rtpg_mapalgebra.c 2018-12-03 09:03:57 UTC (rev 17095)
@@ -5754,11 +5754,7 @@
/* prep function call data */
-#if POSTGIS_PGSQL_VERSION <= 90
- InitFunctionCallInfoData(cbdata, &cbinfo, 3, InvalidOid, NULL);
-#else
InitFunctionCallInfoData(cbdata, &cbinfo, 3, InvalidOid, NULL, NULL);
-#endif
memset(cbdata.argnull, FALSE, sizeof(bool) * 3);
/* check that the function isn't strict if the args are null. */
@@ -6861,11 +6857,7 @@
- InitFunctionCallInfoData(ufc_info, &ufl_info, ufl_info.fn_nargs, InvalidOid, NULL);
-#else
InitFunctionCallInfoData(ufc_info, &ufl_info, ufl_info.fn_nargs, InvalidOid, NULL, NULL);
-#endif
memset(ufc_info.argnull, FALSE, sizeof(bool) * ufl_info.fn_nargs);
if (ufl_info.fn_nargs != 4)
Modified: trunk/regress/core/Makefile.in
--- trunk/regress/core/Makefile.in 2018-12-01 21:22:42 UTC (rev 17094)
+++ trunk/regress/core/Makefile.in 2018-12-03 09:03:57 UTC (rev 17095)
@@ -23,7 +23,6 @@
POSTGIS_MINOR_VERSION=@POSTGIS_MINOR_VERSION@
HAVE_JSON=@HAVE_JSON@
HAVE_PROTOBUF=@HAVE_PROTOBUF@
-HAVE_BRIN=@HAVE_BRIN@
HAVE_SPGIST=@HAVE_SPGIST@
INTERRUPTTESTS=@INTERRUPTTESTS@
@@ -86,11 +85,13 @@
forcecurve \
geography \
geometric_median \
+ hausdorff \
in_geohash \
in_gml \
in_kml \
in_encodedpolyline \
iscollection \
+ knn_recheck \
legacy \
long_xact \
lwgeom_regress \
@@ -107,6 +108,7 @@
quantize_coordinates \
regress \
regress_bdpoly \
+ regress_buffer_params \
regress_gist_index_nd \
regress_index \
regress_index_nulls \
@@ -137,43 +139,13 @@
swapordinates \
summary \
temporal \
+ temporal_knn \
tickets \
twkb \
typmod \
wkb \
wkt \
- wmsservers
-ifeq ($(shell expr $(POSTGIS_PGSQL_VERSION) "<" 95),1)
- # Index supported KNN only available in PostgreSQL 9.1 and higher
- # For 9.5 and higher, use the recheck suite instead
- TESTS += knn
-endif
-ifeq ($(shell expr $(POSTGIS_PGSQL_VERSION) ">=" 95),1)
- # Index supported KNN recheck only available in PostgreSQL 9.5 and higher
- TESTS += knn_recheck \
- temporal_knn
-endif
-TESTS += \
- hausdorff \
- regress_buffer_params
-ifeq ($(shell expr $(POSTGIS_GEOS_VERSION) ">=" 37),1)
- # GEOS-3.7 adds:
- # ST_FrechetDistance
- TESTS += \
- frechet
-endif
-# GEOS-3.3 adds:
-# ST_RelateMatch, ST_IsValidDetail, ST_SharedPaths ,
-# ST_Snap, ST_UnaryUnion, ST_MakeClean
-TESTS += \
+ wmsservers \
offsetcurve \
relatematch \
isvaliddetail \
@@ -182,13 +154,29 @@
node \
unaryunion \
clean \
- relate_bnr
+ relate_bnr \
+ delaunaytriangles \
+ clipbybox2d \
+ subdivide \
+ voronoi \
+ regress_brin_index \
+ regress_brin_index_3d \
+ regress_brin_index_geography
-# GEOS-3.4 adds:
-# ST_DelaunayTriangles
-TESTS += \
- delaunaytriangles
+ifeq ($(shell expr $(POSTGIS_GEOS_VERSION) ">=" 36),1)
+ # GEOS-3.6 adds:
+ # ST_MinimumClearance
+ TESTS += \
+ minimum_clearance \
+ oriented_envelope
+endif
+ifeq ($(shell expr $(POSTGIS_GEOS_VERSION) ">=" 37),1)
+ # GEOS-3.7 adds:
+ # ST_FrechetDistance
+ TESTS += \
+ frechet
+endif
ifeq ($(INTERRUPTTESTS),yes)
# Allow CI servers to configure --with-interrupt-tests
@@ -198,24 +186,6 @@
interrupt_buffer
endif
-ifeq ($(shell expr $(POSTGIS_GEOS_VERSION) ">=" 35),1)
- # GEOS-3.5 adds:
- # ST_ClipByBox2d, ST_Subdivide, ST_Voronoi
- TESTS += \
- clipbybox2d \
- subdivide \
- voronoi
-endif
-ifeq ($(shell expr $(POSTGIS_GEOS_VERSION) ">=" 36),1)
- # GEOS-3.6 adds:
- # ST_MinimumClearance
- TESTS += \
- minimum_clearance \
- oriented_envelope
-endif
ifeq ($(HAVE_JSON),yes)
# JSON-C adds:
# ST_GeomFromGeoJSON()
@@ -223,13 +193,6 @@
in_geojson
endif
-ifeq ($(HAVE_BRIN),yes)
- TESTS += \
- regress_brin_index \
- regress_brin_index_3d \
- regress_brin_index_geography
-endif
ifeq ($(HAVE_SPGIST),yes)
TESTS += \
regress_spgist_index_2d \
@@ -242,12 +205,9 @@
# ST_AsMVT, ST_AsGeobuf
TESTS += \
mvt \
- geobuf
-ifeq ($(shell expr $(POSTGIS_PGSQL_VERSION) ">=" 94),1)
- TESTS += \
+ geobuf \
mvt_jsonb
endif
-endif
all install uninstall:
