[postgis-tickets] r17096 - Remove knn tests
Darafei
komzpa at gmail.com
Mon Dec 3 12:08:58 PST 2018
Author: komzpa
Date: 2018-12-03 12:08:58 -0800 (Mon, 03 Dec 2018)
New Revision: 17096
Removed:
trunk/regress/core/knn.sql
trunk/regress/core/knn_expected
Remove knn tests
Closes #4229
Deleted: trunk/regress/core/knn.sql
--- trunk/regress/core/knn.sql 2018-12-03 09:03:57 UTC (rev 17095)
+++ trunk/regress/core/knn.sql 2018-12-03 20:08:58 UTC (rev 17096)
@@ -1,98 +0,0 @@
-CREATE OR REPLACE FUNCTION qnodes(q text) RETURNS text
-LANGUAGE 'plpgsql' AS
-DECLARE
- exp TEXT;
- mat TEXT[];
- ret TEXT[];
-BEGIN
- FOR exp IN EXECUTE 'EXPLAIN ' || q
- LOOP
- --RAISE NOTICE 'EXP: %', exp;
- mat := regexp_matches(exp, ' *(?:-> *)?(.*Scan)');
- --RAISE NOTICE 'MAT: %', mat;
- IF mat IS NOT NULL THEN
- ret := array_append(ret, mat[1]);
- END IF;
- --RAISE NOTICE 'RET: %', ret;
- END LOOP;
- RETURN array_to_string(ret,',');
-END;
-\i regress_lots_of_points.sql
--- Index-supported KNN query
-CREATE INDEX test_gist_2d on test using gist (the_geom);
-SELECT '<-> idx', qnodes('select * from test order by the_geom <-> ST_MakePoint(0,0) LIMIT 1');
-SELECT '<-> res1',num,
- (the_geom <-> 'POINT(2.5 2.5)'::geometry)::numeric(10,2),
- ST_astext(the_geom) from test
- order by the_geom <-> 'POINT(2.5 2.5)'::geometry LIMIT 1;
--- Full table extent: BOX(0.0439142361 0.0197799355,999.955261 999.993652)
-SELECT '<#> idx', qnodes('select * from test order by the_geom <#> ST_MakePoint(0,0) LIMIT 1');
-SELECT '<#> res1',num,
- (the_geom <#> 'LINESTRING(1000 0,1005 5)'::geometry)::numeric(10,2),
- order by the_geom <#> 'LINESTRING(1000 0,1005 5)'::geometry LIMIT 1;
--- Index-supported nd-KNN query
-DROP INDEX test_gist_2d;
-UPDATE test set the_geom = ST_MakePoint(
- ST_X(the_geom), ST_Y(the_geom),
- num, -num);
-SELECT '<<->> seq', qnodes('select * from test order by the_geom <<->> ST_MakePoint(0,0)');
-CREATE INDEX test_gist_nd on test using gist (the_geom gist_geometry_ops_nd);
-ANALYZE test;
--- EXT X Y Z M
--- min 0.0439142361 | 0.0197799355| 1| -50000
--- max 999.955261 | 999.993652 | 50000| -1
---SELECT min(st_x(the_geom)) as minx, min(st_y(the_geom)) as miny,
--- min(st_z(the_geom)) as minz, min(st_m(the_geom)) as minm,
--- max(st_x(the_geom)) as maxx, max(st_y(the_geom)) as maxy,
--- max(st_z(the_geom)) as maxz, max(st_m(the_geom)) as maxm
---FROM test;
-SELECT '<<->> idx', qnodes('select * from test order by the_geom <<->> ST_MakePoint(0,0) LIMIT 1');
-SELECT '<<->> res1',num,
- (the_geom <<->> 'LINESTRING(0 0,5 5)'::geometry)::numeric(10,2),
- order by the_geom <<->> 'LINESTRING(0 0,5 5)'::geometry LIMIT 1;
-SELECT '<<->> res2',num,
- (the_geom <<->> 'POINT(95 23 25024 -25025)'::geometry)::numeric(10,2),
- order by the_geom <<->> 'POINT(95 23 25024 -25025)'::geometry LIMIT 1;
-SELECT '<<->> res3',num,
- (the_geom <<->> 'POINT(631 729 25023 -25022)'::geometry)::numeric(10,2),
- order by the_geom <<->> 'POINT(631 729 25023 -25022)'::geometry LIMIT 1;
--- Cleanup
-DROP FUNCTION qnodes(text);
-DROP TABLE test;
--- nd box centroid distance <<->>
-select '<<->> ndcd1', 'LINESTRING(0 0,0 10,10 10)'::geometry <<->>
- 'LINESTRING(6 2,6 8)'::geometry; -- 1
-select '<<->> ndcd2', 'LINESTRING(0 0,0 10,10 10)'::geometry <<->>
- 'LINESTRING(11 0,19 10)'::geometry; -- 10
-select '<<->> ndcd3', 'POINTM(0 0 0)'::geometry <<->>
- 'POINTM(0 0 5)'::geometry; -- 5
-select '<<->> ndcd4', 'POINTZ(0 0 15)'::geometry <<->>
- 'POINTZ(0 0 10)'::geometry; -- 5
-select '<<->> ndcd5', 'POINTZM(1 2 3 4)'::geometry <<->>
- 'POINTZM(2 3 4 5)'::geometry; -- 2
-select '<<->> ndcd6', 'POINTZM(9 9 3 4)'::geometry <<->>
- 'POINT(9 8)'::geometry; -- 1, higher dimensions overlapping
Deleted: trunk/regress/core/knn_expected
--- trunk/regress/core/knn_expected 2018-12-03 09:03:57 UTC (rev 17095)
+++ trunk/regress/core/knn_expected 2018-12-03 20:08:58 UTC (rev 17096)
@@ -1,15 +0,0 @@
-<-> idx|Index Scan
-<-> res1|48589|0.17|POINT(2.33793712 2.44566727)
-<#> idx|Index Scan
-<#> res1|2057|0.83|POINT(999.173279 3.92185807)
-<<->> seq|Seq Scan
-<<->> idx|Index Scan
-<<->> res1|48589|0.17|POINT ZM (2.33793712 2.44566727 48589 -48589)
-<<->> res2|25025|1.20|POINT ZM (95.6546249 23.0995369 25025 -25025)
-<<->> res3|25023|1.27|POINT ZM (631.060242 729.787354 25023 -25023)
-<<->> ndcd1|1
-<<->> ndcd2|10
-<<->> ndcd3|5
-<<->> ndcd4|5
-<<->> ndcd5|2
-<<->> ndcd6|1
