[postgis-tickets] [PostGIS] #4269: Inconsistent result for ST_Intersects depending on the plan
trac at osgeo.org
Wed Dec 5 00:59:17 PST 2018
Reporter: Algunenano | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.4.7
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by Algunenano):
Plan with `hashjoin` on:
QUERY PLAN
Subquery Scan on _a (cost=0.17..0.51 rows=1 width=9) (actual
time=0.610..2.006 rows=6 loops=1)
-> Hash Join (cost=0.17..0.25 rows=1 width=72) (actual
time=0.135..0.191 rows=6 loops=1)
Hash Cond: (b.blockid = a.blockid)
Join Filter: (a.cid <> b.cid)
Rows Removed by Join Filter: 3
CTE data
-> Append (cost=0.00..0.08 rows=3 width=44) (actual
time=0.008..0.021 rows=3 loops=1)
-> Result (cost=0.00..0.01 rows=1 width=44) (actual
time=0.006..0.007 rows=1 loops=1)
-> Subquery Scan on "*SELECT* 2" (cost=0.00..0.02
rows=1 width=44) (actual time=0.005..0.006 rows=1 loops=1)
-> Result (cost=0.00..0.01 rows=1 width=40)
(actual time=0.002..0.003 rows=1 loops=1)
-> Subquery Scan on "*SELECT* 3" (cost=0.00..0.02
rows=1 width=44) (actual time=0.003..0.004 rows=1 loops=1)
(actual time=0.001..0.002 rows=1 loops=1)
-> CTE Scan on data b (cost=0.00..0.06 rows=3 width=44) (actual
time=0.023..0.032 rows=3 loops=1)
-> Hash (cost=0.08..0.08 rows=1 width=44) (actual
time=0.071..0.071 rows=3 loops=1)
Buckets: 1024 Batches: 1 Memory Usage: 9kB
-> CTE Scan on data a (cost=0.00..0.08 rows=1 width=44)
(actual time=0.012..0.040 rows=3 loops=1)
Filter: ((blockid)::integer = 720)
Planning Time: 2.196 ms
Execution Time: 2.412 ms
(19 rows)
Plan with hashjoin off:
crap=# set enable_hashjoin=off;
SET
crap=# explain analyze Select ST_Intersects(ag, bg), acid, bcid FROM
WITH data AS (
SELECT 1 as cid,720::bigint as blockid, ST_GeomFromText('POLYGON Z
((122427.759 489209.498 14.5066901703871,122395.957 489222.943
14.3997094723791,122399.649 489231.676 4.98556790825181,122431.452
489218.231 5.09216481886026,122427.759 489209.498 14.5066901703871))')
geom
UNION ALL
SELECT 2, 720, ST_GeomFromText('POLYGON Z ((122427.027 489216.053
5.97863674861823,122419.873 489219.077 6.03923989893278,122421.6
489223.163 1.83027232084998,122428.754 489220.138
1.77054008712955,122427.027 489216.053 5.97863674861823))')
UNION ALL
SELECT 3, 720, ST_GeomFromText('POLYGON Z ((122422.267 489220.741
0,122424.396 489219.847 0,122424.396 489219.847 30,122422.267 489220.741
30,122422.267 489220.741 0))')
SELECT
a.cid as acid, b.cid as bcid,
a.geom as ag, b.geom as bg
FROM data a, data b
WHERE a.cid != b.cid
AND a.blockid = b.blockid
AND a.blockid::int = 720
) _A;
QUERY PLAN
Subquery Scan on _a (cost=0.08..0.52 rows=1 width=9) (actual
time=0.726..2.140 rows=6 loops=1)
-> Nested Loop (cost=0.08..0.26 rows=1 width=72) (actual
time=0.058..0.139 rows=6 loops=1)
Join Filter: ((a.cid <> b.cid) AND (a.blockid = b.blockid))
CTE data
time=0.008..0.026 rows=3 loops=1)
rows=1 width=44) (actual time=0.005..0.007 rows=1 loops=1)
-> CTE Scan on data a (cost=0.00..0.08 rows=1 width=44) (actual
time=0.029..0.039 rows=3 loops=1)
time=0.002..0.017 rows=3 loops=3)
Planning Time: 2.194 ms
Execution Time: 2.492 ms
(16 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4269#comment:1>
