[postgis-tickets] [PostGIS] #4270: ST_3DIntersects says 'no' despite geometries intersecting
trac at osgeo.org
Thu Dec 6 04:24:27 PST 2018
Reporter: tilt | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.5.2
Component: sfcgal | Version: 2.5.x
Resolution: | Keywords:
Comment (by komzpa):
ST_3DIntersects in GEOS backend is a plug for ST_3DDWithin(geom, geom, 0):
https://github.com/postgis/postgis/blob/dd281b1e57b590c0339271cedbf5feaf84049cc4/postgis/lwgeom_backend_api.c#L153
We are going to remove it during #4258 and (probably) rename to
ST_3DSurfaceIntersects. May it happen that surfaces of ac intersect, and
surfaces of ab don't? If yes, then it works as expected codewise, and
we'll untangle this in 3.0 by renaming function.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4270#comment:3>
