[postgis-tickets] r17117 - Bump SFCGAL to 1.3.1
Darafei komzpa at gmail.com
Thu Dec 20 09:50:12 PST 2018
Author: komzpa
Date: 2018-12-20 21:50:11 -0800 (Thu, 20 Dec 2018)
New Revision: 17117
   trunk/NEWS
   trunk/README.postgis
   trunk/ci/winnie/build_postgis.sh
   trunk/ci/winnie/package_postgis.sh
   trunk/ci/winnie/regress_postgis.sh
   trunk/configure.ac
   trunk/postgis/lwgeom_sfcgal.c
   trunk/postgis/sfcgal.sql.in
Closes #4268
Closes https://github.com/postgis/postgis/pull/353
Modified: trunk/NEWS
--- trunk/NEWS	2018-12-21 05:44:21 UTC (rev 17116)
+++ trunk/NEWS	2018-12-21 05:50:11 UTC (rev 17117)
@@ -13,12 +13,15 @@
   - #4229, Dropped support for PostgreSQL < 9.5. (Darafei Praliaskouski)
   - #4260, liblwgeom headers are not installed anymore.
            If your project depends on them available, please use
-           librttopo instead. (Darafei Praliaskouski)
+           librttopo instead. (Darafei Praliaskouski)
   - #4258, Remove SFCGAL support for ST_Area, ST_Distance, ST_Intersection,
            ST_Difference, ST_Union (Darafei Praliaskouski)
   - #4267, Enable Proj 6 deprecated APIs (Darafei Praliaskouski, Raúl Marín)
+  - #4268, Bump minimum SFCGAL version to 1.3.1 (Darafei Praliaskouski)
 * New Features *
   - #2902, postgis_geos_noop (Sandro Santilli)
   - #4128, ST_AsMVT support for Feature ID (Stepan Kuzmin)
Modified: trunk/README.postgis
--- trunk/README.postgis	2018-12-21 05:44:21 UTC (rev 17116)
+++ trunk/README.postgis	2018-12-21 05:50:11 UTC (rev 17117)
@@ -81,7 +81,7 @@
   with raster or extension support. To compile without raster support you
   must ``./configure --without-raster`` (also disables extension)
-* CGAL 4.1+ and SFCGAL (Optional) needed for advanced 3D support
+* CGAL 4.1+ and SFCGAL 1.3.1+ (Optional) needed for advanced 3D support
   https://github.com/Oslandia/SFCGAL
Modified: trunk/ci/winnie/build_postgis.sh
--- trunk/ci/winnie/build_postgis.sh	2018-12-21 05:44:21 UTC (rev 17116)
+++ trunk/ci/winnie/build_postgis.sh	2018-12-21 05:50:11 UTC (rev 17117)
@@ -12,7 +12,6 @@
 #POSTGIS_MINOR_VERSION=1
 #POSTGIS_MICRO_VERSION=0SVN
 #export GCC_TYPE=gcc48  #for pre-4.8.0 compiles this is blank
-export SFCGAL_VER=1.3.6
 export GEOS_VER=3.8.0dev
 export GDAL_VER=2.2.4
 export PROJ_VER=4.9.3
@@ -21,8 +20,6 @@
 export PROTOBUF_VER=3.2.0
 export PROTOBUFC_VER=1.2.1
 export CGAL_VER=4.11
 export LIBXML_VER=2.7.8
 if [[ "${GCC_TYPE}" == *gcc48* ]] ; then
Modified: trunk/ci/winnie/package_postgis.sh
--- trunk/ci/winnie/package_postgis.sh	2018-12-21 05:44:21 UTC (rev 17116)
+++ trunk/ci/winnie/package_postgis.sh	2018-12-21 05:50:11 UTC (rev 17117)
@@ -12,7 +12,6 @@
 #export OS_BUILD=32
 #export GCC_TYPE=
Modified: trunk/ci/winnie/regress_postgis.sh
--- trunk/ci/winnie/regress_postgis.sh	2018-12-21 05:44:21 UTC (rev 17116)
+++ trunk/ci/winnie/regress_postgis.sh	2018-12-21 05:50:11 UTC (rev 17117)
@@ -1,6 +1,5 @@
 #!/bin/bash
 set -e
Modified: trunk/configure.ac
--- trunk/configure.ac	2018-12-21 05:44:21 UTC (rev 17116)
+++ trunk/configure.ac	2018-12-21 05:50:11 UTC (rev 17117)
@@ -740,7 +740,10 @@
 		SFCGAL_MAJOR_VERSION=`echo $SFCGAL_VERSION | cut -d. -f1 | sed 's/[[^0-9]]//g'`
 		SFCGAL_MINOR_VERSION=`echo $SFCGAL_VERSION | cut -d. -f2 | sed 's/[[^0-9]]//g'`
-		POSTGIS_SFCGAL_VERSION="$SFCGAL_MAJOR_VERSION$SFCGAL_MINOR_VERSION"
+		SFCGAL_PATCH_VERSION=`echo $SFCGAL_VERSION | cut -d. -f3 | sed 's/[[^0-9]]//g'`
+		SFCGAL_NUMERIC_PATCH_VERSION=`printf "%02d" $SFCGAL_PATCH_VERSION`
+		SFCGAL_NUMERIC_MINOR_VERSION=`printf "%02d" $SFCGAL_MINOR_VERSION`
+		POSTGIS_SFCGAL_VERSION="$SFCGAL_MAJOR_VERSION$SFCGAL_NUMERIC_MINOR_VERSION$SFCGAL_NUMERIC_PATCH_VERSION"
 		AC_DEFINE_UNQUOTED([POSTGIS_SFCGAL_VERSION], [$POSTGIS_SFCGAL_VERSION], [SFCGAL library version at build time])
 		AC_SUBST([POSTGIS_SFCGAL_VERSION])
@@ -751,10 +754,9 @@
         		SFCGAL="sfcgal"
 			HAVE_SFCGAL="yes"
 		fi
-		if test ! "$POSTGIS_SFCGAL_VERSION" -ge 11; then
-			AC_MSG_ERROR([PostGIS requires SFCGAL >= 1.1.0 (found $SFCGAL_VERSION)])
+		if test ! "$POSTGIS_SFCGAL_VERSION" -ge 10301; then
+			AC_MSG_ERROR([PostGIS requires SFCGAL >= 1.3.1 (found $SFCGAL_VERSION)])
 		fi
 	else
 		if test "x$with_sfcgal" != "xauto"; then
 			AC_MSG_ERROR([sfcgal-config cannot be found. Please install sfcgal])
Modified: trunk/postgis/lwgeom_sfcgal.c
--- trunk/postgis/lwgeom_sfcgal.c	2018-12-21 05:44:21 UTC (rev 17116)
+++ trunk/postgis/lwgeom_sfcgal.c	2018-12-21 05:50:11 UTC (rev 17117)
@@ -374,14 +374,6 @@
 PG_FUNCTION_INFO_V1(sfcgal_approximate_medial_axis);
 Datum sfcgal_approximate_medial_axis(PG_FUNCTION_ARGS)
-#if POSTGIS_SFCGAL_VERSION < 12
-	lwpgerror(
-	    "The SFCGAL version this PostGIS binary "
-	    "was compiled against (%d) doesn't support "
-	    "'sfcgal_geometry_approximate_medial_axis' function (1.2.0+ required)",
-	    POSTGIS_SFCGAL_VERSION);
-	PG_RETURN_NULL();
-#else  /* POSTGIS_SFCGAL_VERSION >= 12 */
 	GSERIALIZED *input, *output;
 	sfcgal_geometry_t *geom;
 	sfcgal_geometry_t *result;
@@ -401,7 +393,6 @@
 	sfcgal_geometry_delete(result);
 	PG_RETURN_POINTER(output);
-#endif /* POSTGIS_SFCGAL_VERSION >= 12 */
 PG_FUNCTION_INFO_V1(sfcgal_intersection3D);
Modified: trunk/postgis/sfcgal.sql.in
--- trunk/postgis/sfcgal.sql.in	2018-12-21 05:44:21 UTC (rev 17116)
+++ trunk/postgis/sfcgal.sql.in	2018-12-21 05:50:11 UTC (rev 17117)
@@ -100,31 +100,8 @@
 -- Availability: 2.2.0
 CREATE OR REPLACE FUNCTION ST_ApproximateMedialAxis(geometry)
        RETURNS geometry
-       AS $$
-       DECLARE
-         poly alias for $1;
-         ret GEOMETRY;
-       BEGIN
-         WITH components AS (
-           SELECT (ST_Dump(ST_StraightSkeleton(poly))).geom
-         filtered AS (
-           SELECT ST_Collect(geom) g
-           FROM components
-           WHERE NOT ST_Touches(geom, ST_Boundary(poly))
-         SELECT
-          COALESCE(g, ST_SetSRID('MULTILINESTRING EMPTY'::geometry, ST_Srid(poly)))
-         INTO ret
-         FROM filtered;
-         RETURN ret;
-       END; $$
-       LANGUAGE 'plpgsql'
-#else // POSTGIS_SFCGAL_VERSION >= 12
        AS 'MODULE_PATHNAME','sfcgal_approximate_medial_axis'
        LANGUAGE 'c'
-#endif // POSTGIS_SFCGAL_VERSION >= 12
        IMMUTABLE STRICT  _PARALLEL
        COST 100;
