[postgis-tickets] [PostGIS] #4279: Can't find proj
trac at osgeo.org
Tue Dec 25 13:47:42 PST 2018
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.3.9
Component: buildbots | Version: 2.3.x
Keywords: |
I noticed winnies and bessies failing on 2,4, 2.5 and 3.0
with notice
On bessie
00:52:01 checking for shared library run path origin... /bin/sh: cannot
open build-aux/config.rpath: No such file or directory
00:52:01 done
00:52:01 checking for CFPreferencesCopyAppValue... no
00:52:01 checking for CFLocaleCopyCurrent... no
00:52:01 checking for GNU gettext in libc... no
00:52:01 checking for iconv... yes
00:52:02 checking for working iconv... yes
00:52:02 checking for GNU gettext in libintl... no
00:52:02 checking whether to use NLS... no
00:52:02 checking for proj_api.h... no
00:52:02 configure: error: could not find proj_api.h - you may need to
specify the directory of a PROJ.4 installation using --with-projdir
00:52:02 *** Error code 1
00:52:02
On winnie
Using user-specified proj directory: /projects/proj/rel-4.9.3w64gcc48
configure: error: could not find proj_api.h - you may need to specify the
Seems to be a result of commit r17109 (for 2.5) and related commits for
3.0, 2.4 ( r17110 ), and 2.3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4279>
