[postgis-tickets] [PostGIS] #1871: [raster] ST_Approx raster stats functions are not documented
PostGIS trac at osgeo.org
Sat Dec 29 08:56:49 PST 2018
  Reporter:  pracine        |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 2.4.6
 Component:  documentation  |    Version:  2.0.x
Resolution:                 |   Keywords:
Comment (by robe):
 sunveersingh,
 Hopefully this will help - if you have any more questions, join our
 development mailing list.
 SHORT ANSWER
 1) For new functions (even if they are not knew but just aren't
 documented) use this template
 https://trac.osgeo.org/postgis/browser/trunk/doc/template.xml
 2) Attach the updated file to this ticket.
 LONG ANSWER
 1) Join our developer mailing list especially if you have questions -
 https://lists.osgeo.org/mailman/listinfo/postgis-devel
 2) Don't be shy asking questions on the list. No one should bite you even
 if you ask a stupid question. We all ask stupid questions.  If per chance
 someone SHOULD bite you, I'll bite them back and you can bite them too :).
 3) For documentation - we use docbook, which is an xml format - the raster
 functions are all documented in
 doc/reference_raster.xml  and general raster usage manual is
 doc/using_raster_dataman.xml
 These you can pull from any of our git and svn mirrors listed way at the
 bottom of this page - https://postgis.net/source/ (or the latest tar ball
 https://postgis.net/stuff/postgis-3.0.0dev.tar.gz )
 Use the trunk version
 4) When you make changes to existing function - you can create a patch to
 the file and attach it to this ticket.
 git or svn or regular old patch are all fine.
 For new functions such as this one -- just the body of the functions is
 sufficient -
 and you follow the format of our template -
 You can attach each as separate file to this ticket or just as a single
 file, repeating the template format of each new function.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1871#comment:10>
