[postgis-tickets] [PostGIS] #4007: ST_SetBandPath
trac at osgeo.org
Thu Feb 1 10:41:04 PST 2018
Reporter: Bborie Park | Owner: Bborie Park
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS Fund Me
Component: raster | Version: trunk
Resolution: | Keywords:
Description changed by Bborie Park:
Old description:
> Add support for changing the path of an out-db raster.
> boolean ST_SetBandPath(rast raster, bandnum integer, out_path text,
> out_bandnum integer, force boolean DEFAULT FALSE)
> {{force}} parameter is to prevent the standard validation that takes
> place when setting the path of an out-db band
New description:
'''force''' parameter is to prevent the standard validation that takes
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4007#comment:1>
