[postgis-tickets] [PostGIS] #4010: Sort nodes in circtree before descending for distance calculation
trac at osgeo.org
Fri Feb 2 14:20:49 PST 2018
Reporter: pramsey | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: trunk
Keywords: |
As discovered in working on trying to get performant edge trees in planar
space, there is a potentially very large speedup available in doing a
tree-based distance calculation in sorting the tree nodes before
descending into them, since doing so increases the odds of getting min/max
constraints that will prune dead branches in later descents.
Applying the same idea to the CIRC_NODE trees used in geography
calculations, a speed-up of 3x for a query of all countries against Canada
was observed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4010>
