[postgis-tickets] r16374 - #4006, cast json/jsonb to text in ST_GeomFromGeoJSON
Paul Ramsey
pramsey at cleverelephant.ca
Thu Feb 8 11:11:45 PST 2018
Author: pramsey
Date: 2018-02-08 11:11:45 -0800 (Thu, 08 Feb 2018)
New Revision: 16374
trunk/postgis/postgis.sql.in
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2018-02-07 07:47:55 UTC (rev 16373)
+++ trunk/postgis/postgis.sql.in 2018-02-08 19:11:45 UTC (rev 16374)
@@ -4293,6 +4293,18 @@
AS 'MODULE_PATHNAME','geom_from_geojson'
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
+-- Availability: 2.5.0
+CREATE OR REPLACE FUNCTION ST_GeomFromGeoJson(json)
+ RETURNS geometry
+ AS 'SELECT @extschema at .ST_GeomFromGeoJson($1::text)'
+ LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
+CREATE OR REPLACE FUNCTION ST_GeomFromGeoJson(jsonb)
+ RETURNS geometry
-- Availability: 2.0.0
CREATE OR REPLACE FUNCTION postgis_libjson_version()
RETURNS text
