[postgis-tickets] [PostGIS] #4012: trunk is failing on median tests
PostGIS trac at osgeo.org
Thu Feb 8 12:59:21 PST 2018
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.5.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16375" 16375]:
 #!CommitTicketReference repository="" revision="16375"
 Fix build tests around geometric median (Raúl Marín Rodríguez)
 Closes https://github.com/postgis/postgis/pull/205
 Closes #4012
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4012#comment:2>
