[postgis-tickets] r16378 - check_gdal: Don't assume failure when the datapath is invalid
Darafei
komzpa at gmail.com
Tue Feb 13 05:30:34 PST 2018
Author: komzpa
Date: 2018-02-13 05:30:33 -0800 (Tue, 13 Feb 2018)
New Revision: 16378
trunk/raster/test/regress/check_gdal.sql
trunk/raster/test/regress/check_gdal_expected
Patch by Raúl Marín Rodríguez
Closes https://github.com/postgis/postgis/pull/206
Closes #4013
Modified: trunk/raster/test/regress/check_gdal.sql
--- trunk/raster/test/regress/check_gdal.sql 2018-02-13 13:08:25 UTC (rev 16377)
+++ trunk/raster/test/regress/check_gdal.sql 2018-02-13 13:30:33 UTC (rev 16378)
@@ -5,13 +5,8 @@
THEN false
ELSE NULL
END;
-SET postgis.gdal_datapath = '';
-SELECT
- CASE
- WHEN strpos(postgis_gdal_version(), 'GDAL_DATA') <> 0
- THEN NULL
- ELSE TRUE
- END;
+SET postgis.gdal_datapath = 'invalid_path';
+SHOW postgis.gdal_datapath;
SET postgis.gdal_datapath = default;
SELECT
CASE
Modified: trunk/raster/test/regress/check_gdal_expected
--- trunk/raster/test/regress/check_gdal_expected 2018-02-13 13:08:25 UTC (rev 16377)
+++ trunk/raster/test/regress/check_gdal_expected 2018-02-13 13:30:33 UTC (rev 16378)
@@ -1,3 +1,4 @@
+invalid_path
t
DISABLE_ALL
ENABLE_ALL
