[postgis-tickets] [PostGIS] #4020: Casting BOX3D to geometry invalid
trac at osgeo.org
Mon Feb 19 06:06:07 PST 2018
Reporter: mat | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.4.x
Keywords: |
When casting an actual BOX3D to geometry, the result is invalid.
If it has a width of 0 in one ore more dimensions, it is fine.
The problem is that the orientations of the top, front and left side of
the polyhedral surface are wrong.
Example:
> SELECT ST_AsText('BOX3D(1 2 3,4 5 6)'::BOX3D);
POLYHEDRALSURFACE Z (((1 2 3,1 5 3,4 5 3,4 2 3,1 2 3)),((1 2 6,1 5 6,4 5
6,4 2 6,1 2 6)),((1 2 3,1 5 3,1 5 6,1 2 6,1 2 3)),((4 2 3,4 5 3,4 5 6,4 2
6,4 2 3)),((1 2 3,4 2 3,4 2 6,1 2 6,1 2 3)),((1 5 3,4 5 3,4 5 6,1 5 6,1 5
3)))
-- expected correct result:
POLYHEDRALSURFACE Z (((1 2 3,1 5 3,4 5 3,4 2 3,1 2 3)),((1 2 6,4 2 6,4 5
6,1 5 6,1 2 6)),((1 2 3,1 2 6,1 5 6,1 5 3,1 2 3)),((4 2 3,4 5 3,4 5 6,4 2
6,4 2 3)),((1 2 3,4 2 3,4 2 6,1 2 6,1 2 3)),((1 5 3,1 5 6,4 5 6,4 5 3,1 5
3)))
Notice the switched coordinates for the second (top), third (left) and
sixth (front) polygon.
This results e.g. in ST_Volume and ST_3DArea not accepting "true" BOX3Ds:
> SELECT ST_3DArea('BOX3D(1 2 3,1 5 6)'::BOX3D); -- works
9
> SELECT ST_3DArea('BOX3D(1 2 3,4 5 6)'::BOX3D); -- doesn't work
SQL Error [XX000]: ERROR: Solid is invalid : PolyhedralSurface (shell) 0
is invalid: not connected : SOLID((((1/1 2/1 3/1,1/1 5/1 3/1,4/1 5/1
3/1,4/1 2/1 3/1,1/1 2/1 3/1)),((1/1 2/1 6/1,1/1 5/1 6/1,4/1 5/1 6/1,4/1
2/1 6/1,1/1 2/1 6/1)),((1/1 2/1 3/1,1/1 5/1 3/1,1/1 5/1 6/1,1/1 2/1
I think the error is at {{{postgis/lwgeom_box3d.c}}}, lines 325-342.
I'm using:
PostgreSQL 10.1, compiled by Visual C++ build 1800, 64-bit POSTGIS="2.4.3
r16312" PGSQL="100" GEOS="3.6.2-CAPI-1.10.2 4d2925d" SFCGAL="1.3.2"
PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.3, released 2017/11/20"
LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4020>
