[postgis-tickets] r16388 - PROJ: Cleanup point4d_transform and	lwproj_from_string
    Darafei
    komzpa at gmail.com
    Tue Feb 20 06:00:58 PST 2018
Author: komzpa
Date: 2018-02-20 06:00:57 -0800 (Tue, 20 Feb 2018)
New Revision: 16388
   trunk/liblwgeom/lwgeom_transform.c
   trunk/regress/regress_proj_expected
Patch by Raúl Marín Rodríguez
Closes https://github.com/postgis/postgis/pull/212
Closes #4016
Modified: trunk/liblwgeom/lwgeom_transform.c
--- trunk/liblwgeom/lwgeom_transform.c	2018-02-20 11:27:16 UTC (rev 16387)
+++ trunk/liblwgeom/lwgeom_transform.c	2018-02-20 14:00:57 UTC (rev 16388)
@@ -130,93 +130,48 @@
 int
 point4d_transform(POINT4D *pt, projPJ srcpj, projPJ dstpj)
+	POINT3D orig_pt = {pt->x, pt->y, pt->z}; /* Copy for error report*/
-	POINT4D orig_pt;
-	/* Make a copy of the input point so we can report the original should an error occur */
-	orig_pt.x = pt->x;
-	orig_pt.y = pt->y;
-	orig_pt.z = pt->z;
 	if (pj_is_latlong(srcpj)) to_rad(pt) ;
-	LWDEBUGF(4, "transforming POINT(%f %f) from '%s' to '%s'", orig_pt.x, orig_pt.y, pj_get_def(srcpj,0), pj_get_def(dstpj,0));
+	LWDEBUGF(4, "transforming POINT(%f %f) from '%s' to '%s'",
+		 orig_pt.x, orig_pt.y, pj_get_def(srcpj,0), pj_get_def(dstpj,0));
 	if (pj_transform(srcpj, dstpj, 1, 0, &(pt->x), &(pt->y), &(pt->z)) != 0)
-		int* pj_errno_ref = pj_get_errno_ref();
-		int pj_errno_val = *pj_errno_ref;
-		/* Force a reset of pj_errno to avoid future errors */
-		*pj_errno_ref = 0;
+		int pj_errno_val = *pj_get_errno_ref();
 		if (pj_errno_val == -38)
-			lwnotice("PostGIS was unable to transform the point because either no grid shift files were found, or the point does not lie within the range for which the grid shift is defined. Refer to the ST_Transform() section of the PostGIS manual for details on how to configure PostGIS to alter this behaviour.");
+			lwnotice("PostGIS was unable to transform the point because either no grid"
+				 " shift files were found, or the point does not lie within the "
+				 "range for which the grid shift is defined. Refer to the "
+				 "ST_Transform() section of the PostGIS manual for details on how "
+				 "to configure PostGIS to alter this behaviour.");
 			lwerror("transform: couldn't project point (%g %g %g): %s (%d)",
-			        orig_pt.x, orig_pt.y, orig_pt.z, pj_strerrno(pj_errno_val), pj_errno_val);
-			return 0;
+				orig_pt.x, orig_pt.y, orig_pt.z,
+				pj_strerrno(pj_errno_val), pj_errno_val);
 		else
-			return 0;
+		return LW_FAILURE;
 	if (pj_is_latlong(dstpj)) to_dec(pt);
-	return 1;
+	return LW_SUCCESS;
 projPJ
 lwproj_from_string(const char *str1)
-	int t;
-	char *params[1024];  /* one for each parameter */
-	char *loc;
-	char *str;
-	size_t slen;
-	projPJ result;
-	if (str1 == NULL) return NULL;
-	slen = strlen(str1);
-	if (slen == 0) return NULL;
-	str = lwalloc(slen+1);
-	strcpy(str, str1);
-	 * first we split the string into a bunch of smaller strings,
-	 * based on the " " separator
-	params[0] = str; /* 1st param, we'll null terminate at the " " soon */
-	loc = str;
-	t = 1;
-	while  ((loc != NULL) && (*loc != 0) )
+	if (!str1 || str1[0] == '\0')
-		loc = strchr(loc, ' ');
-		if (loc != NULL)
-			*loc = 0; /* null terminate */
-			params[t] = loc+1;
-			loc++; /* next char */
-			t++; /*next param */
-	if (!(result=pj_init(t, params)))
-		lwfree(str);
 		return NULL;
-	lwfree(str);
-	return result;
+	return pj_init_plus(str1);
Modified: trunk/regress/regress_proj_expected
--- trunk/regress/regress_proj_expected	2018-02-20 11:27:16 UTC (rev 16387)
+++ trunk/regress/regress_proj_expected	2018-02-20 14:00:57 UTC (rev 16388)
@@ -10,4 +10,4 @@
 9|POINT(574600 5316780)
 10|POINT(574600 5316780)
 11|SRID=100001;POINT(574600 5316780)
-ERROR:  transform_geom: couldn't parse proj4 output string: 'invalid projection': projection not named
+ERROR:  transform_geom: couldn't parse proj4 output string: 'invalid projection': no arguments in initialization list
