[postgis-tickets] [PostGIS] #2614: Prepared geometry support for ST_DWithin
PostGIS trac at osgeo.org
Tue Feb 20 12:40:01 PST 2018
  Reporter:  robe         |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  high         |  Milestone:  PostGIS 2.5.0
 Component:  postgis      |    Version:  trunk
Resolution:               |   Keywords:
Comment (by pramsey):
 In [changeset:"16393" 16393]:
 #!CommitTicketReference repository="" revision="16393"
 Edge tree index on geometries makes distance calculations on large
 geometries
 go much faster. Needs to be used selectively and potentially with a
 caching
 component for maximum effect. Test it out using _ST_DistanceRectTree(geom,
 geom)
 for now.
 References #2614
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2614#comment:8>
