[postgis-tickets] r16405 - Fix cast from box3d to geometry
Darafei
komzpa at gmail.com
Thu Feb 22 03:09:37 PST 2018
Author: komzpa
Date: 2018-02-22 03:09:37 -0800 (Thu, 22 Feb 2018)
New Revision: 16405
trunk/NEWS
trunk/postgis/lwgeom_box3d.c
trunk/regress/regress_expected
trunk/regress/sfcgal/regress_expected
Patch by Matthias Bay
Closes https://github.com/postgis/postgis/pull/214
Closes #4020
Modified: trunk/NEWS
--- trunk/NEWS 2018-02-22 10:09:36 UTC (rev 16404)
+++ trunk/NEWS 2018-02-22 11:09:37 UTC (rev 16405)
@@ -39,6 +39,8 @@
(Darafei Praliaskouski)
- #3986, ST_AsText now has second argument to limit decimal digits
(Marc Ducobu, Darafei Praliaskouski)
+ - #4020, Casting from box3d to geometry now returns correctly connected
+ PolyhedralSurface (Matthias Bay)
PostGIS 2.4.0
2017/09/30
Modified: trunk/postgis/lwgeom_box3d.c
--- trunk/postgis/lwgeom_box3d.c 2018-02-22 10:09:36 UTC (rev 16404)
+++ trunk/postgis/lwgeom_box3d.c 2018-02-22 11:09:37 UTC (rev 16405)
@@ -326,10 +326,10 @@
&points[0], &points[1], &points[2], &points[3]));
/* add top polygon */
geoms[1] = lwpoly_as_lwgeom(lwpoly_construct_rectangle(LW_TRUE, LW_FALSE,
- &points[4], &points[5], &points[6], &points[7]));
+ &points[4], &points[7], &points[6], &points[5]));
/* add left polygon */
geoms[2] = lwpoly_as_lwgeom(lwpoly_construct_rectangle(LW_TRUE, LW_FALSE,
- &points[0], &points[1], &points[5], &points[4]));
+ &points[0], &points[4], &points[5], &points[1]));
/* add right polygon */
geoms[3] = lwpoly_as_lwgeom(lwpoly_construct_rectangle(LW_TRUE, LW_FALSE,
&points[3], &points[2], &points[6], &points[7]));
@@ -338,7 +338,7 @@
&points[0], &points[3], &points[7], &points[4]));
/* add front polygon */
geoms[5] = lwpoly_as_lwgeom(lwpoly_construct_rectangle(LW_TRUE, LW_FALSE,
- &points[1], &points[2], &points[6], &points[5]));
+ &points[1], &points[5], &points[6], &points[2]));
geom = (LWGEOM *) lwcollection_construct(POLYHEDRALSURFACETYPE,
SRID_UNKNOWN, NULL, ngeoms, geoms);
Modified: trunk/regress/regress_expected
--- trunk/regress/regress_expected 2018-02-22 10:09:36 UTC (rev 16404)
+++ trunk/regress/regress_expected 2018-02-22 11:09:37 UTC (rev 16405)
@@ -92,7 +92,7 @@
107c|POLYGON((2 3 5,2 8 5,6 8 5,6 3 5,2 3 5))
107d|POLYGON((1 -1 4,2 -1 4,2 -1 9,1 -1 9,1 -1 4))
107e|POLYGON((-1 3 5,-1 6 5,-1 6 8,-1 3 8,-1 3 5))
-107f|POLYHEDRALSURFACE(((1 2 3,1 5 3,4 5 3,4 2 3,1 2 3)),((1 2 6,1 5 6,4 5 6,4 2 6,1 2 6)),((1 2 3,1 5 3,1 5 6,1 2 6,1 2 3)),((4 2 3,4 5 3,4 5 6,4 2 6,4 2 3)),((1 2 3,4 2 3,4 2 6,1 2 6,1 2 3)),((1 5 3,4 5 3,4 5 6,1 5 6,1 5 3)))
+107f|POLYHEDRALSURFACE(((1 2 3,1 5 3,4 5 3,4 2 3,1 2 3)),((1 2 6,4 2 6,4 5 6,1 5 6,1 2 6)),((1 2 3,1 2 6,1 5 6,1 5 3,1 2 3)),((4 2 3,4 5 3,4 5 6,4 2 6,4 2 3)),((1 2 3,4 2 3,4 2 6,1 2 6,1 2 3)),((1 5 3,1 5 6,4 5 6,4 5 3,1 5 3)))
108|2
109|4
110|6
Modified: trunk/regress/sfcgal/regress_expected
--- trunk/regress/sfcgal/regress_expected 2018-02-22 10:09:36 UTC (rev 16404)
+++ trunk/regress/sfcgal/regress_expected 2018-02-22 11:09:37 UTC (rev 16405)
@@ -121,7 +121,7 @@
108|2
109|4
110|6
