[postgis-tickets] r16411 - Backport ci changes to 2.3
Regina Obe lr at pcorp.us
Thu Feb 22 02:22:10 PST 2018
Author: robe
Date: 2018-02-22 14:22:10 -0800 (Thu, 22 Feb 2018)
New Revision: 16411
   branches/2.3/ci/winnie/build_postgis.sh
   branches/2.3/ci/winnie/package_postgis.sh
   branches/2.3/ci/winnie/regress_postgis.sh
Modified: branches/2.3/ci/winnie/build_postgis.sh
--- branches/2.3/ci/winnie/build_postgis.sh	2018-02-22 19:44:06 UTC (rev 16410)
+++ branches/2.3/ci/winnie/build_postgis.sh	2018-02-22 22:22:10 UTC (rev 16411)
@@ -2,21 +2,25 @@
 set -e
 #### $Id:build_postgis210.sh 10208 2012-08-30 05:38:22Z robe $
 #all these get passed in by jenkins
-#export OS_BUILD=64
+#export OS_BUILD=64
 #export PG_VER=9.2beta2
 #export PGHOST=localhost
 #export PGPORT=8442
 #export PGUSER=postgres
-#export GEOS_VER=3.4.0dev
-#export GDAL_VER=1.9.1
 #POSTGIS_SVN_REVISION=passed_in_by_buildbot
 #POSTGIS_MAJOR_VERSION=2
 #POSTGIS_MINOR_VERSION=1
 #POSTGIS_MICRO_VERSION=0SVN
 #export GCC_TYPE=gcc48  #for pre-4.8.0 compiles this is blank
-#export JSON_VER=0.9
-#export SFCGAL_VER=1.0.4
-#export PROJ_VER=4.8.0
+export SFCGAL_VER=1.3.2
+export GEOS_VER=3.7.0dev
+export GDAL_VER=2.2.3
+export PROJ_VER=4.9.3
+export PCRE_VER=8.33
+export PROTOBUF_VER=3.2.0
+export PROTOBUFC_VER=1.2.1
+export CGAL_VER=4.11
 export LIBXML_VER=2.7.8
@@ -46,6 +50,7 @@
 echo PATH BEFORE: $PATH
 export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
 #export PROJSO=libproj-0.dll
@@ -52,6 +57,7 @@
 export POSTGIS_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
 export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
+echo POSTGIS_MICRO_VERSION: $POSTGIS_VER
 if [[ "$POSTGIS_MICRO_VERSION"  == *SVN* || "$POSTGIS_MICRO_VERSION"  == *dev* ]] ; then
 	export POSTGIS_SRC=${PROJECTS}/postgis/branches/${POSTGIS_VER}
 else
@@ -61,7 +67,7 @@
 #export POSTGIS_SRC=${PROJECTS}/postgis/trunk
 export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
-# export REL_PGVER=$(echo $PG_VER | tr '.' '')
+# export REL_PGVER=$(echo $PG_VER | tr '.' '')
 # echo $REL_PGVER
 # export RELDIR=${MINGPROJECTS}/postgis/builds/postgis-21
 # export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w64
@@ -68,8 +74,14 @@
 #export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
 export PATH="${PGPATH}/bin:${PGPATH}/lib:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/xsltproc:${PATH}"
+#add protobuf
+export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 echo PATH AFTER: $PATH
+export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig
 cd ${POSTGIS_SRC}
 if [ -e ./GNUMakefile ]; then
 	make distclean
@@ -90,14 +102,13 @@
 fi
 if [ -n "$SFCGAL_VER" ]; then
-	##hard code versions of cgal etc. for now
-	export CGAL_VER=4.2
 	BOOST_VER=1.53.0
 	#BOOST_VER_WU=1_49_0
 	export BOOST_VER_WU=1_53_0
 	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-	CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
+CPPFLAGS="-I${PGPATH}/include -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
+CFLAGS="-Wall -fno-omit-frame-pointer" \
 LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
   --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
   --with-pgconfig=${PGPATH}/bin/pg_config \
@@ -107,10 +118,15 @@
   --with-jsondir=${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
   --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
-  --with-gui --with-gettext=no --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
-  --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}
-elif [ "$POSTGIS_MAJOR_VERSION" == "2" ] ; then
+  --with-gui --with-gettext=no \
+  --with-protobufdir=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE} \
+  --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
+  --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE} \
+  --without-interrupt-tests \
+  --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE}
+else
@@ -117,32 +133,20 @@
   --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
   --with-projdir=${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
   --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/gdal-config \
-else
-CPPFLAGS="-I${PGPATH}/include  -I${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include" \
-    LDFLAGS="-L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib" ./configure \
-  --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config \
-  --with-pgconfig=${PGPATH}/bin/pg_config \
-  --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
-  --with-projdir=${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE} \
-  --with-gdalconfig=${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/gdal-config \
-  --with-jsondir=${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE} \
-  --with-libiconv=${PROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE} \
-  --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
-  --with-gettext=no
 fi;
-#make clean
-##hack to get around boolean incompatibility now only needed for 2.0 (no longer for 2.1)
-if [ "$POSTGIS_MINOR_VERSION" == "0" ] ; then
-cp ${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/include/json/json_object.h.for_compile ${MINGPROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/include/json/json_object.h
-fi;
+make clean
 #patch liblwgeom generated make to get rid of dynamic linking
 sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
+#make uninstall
 make && make install
Modified: branches/2.3/ci/winnie/package_postgis.sh
--- branches/2.3/ci/winnie/package_postgis.sh	2018-02-22 19:44:06 UTC (rev 16410)
+++ branches/2.3/ci/winnie/package_postgis.sh	2018-02-22 22:22:10 UTC (rev 16411)
@@ -9,13 +9,19 @@
 #POSTGIS_MICRO_VERSION=0dev
-#export GDAL_VER=2.0.0
 #export OS_BUILD=32
-#export PROJ_VER=4.9.1
 #export GCC_TYPE=
-#export SFCGAL_VER=1.1.0
-#export PCRE_VER
 if [[ "${GCC_TYPE}" == *gcc48* ]] ; then
 	export PROJECTS=/projects
 	export MINGPROJECTS=/projects
@@ -48,15 +54,15 @@
 	export POSTGIS_SRC=${PROJECTS}/postgis/branches/${POSTGIS_MINOR_VER}
-	export svnurl="http://svn.osgeo.org/postgis/branches/${POSTGIS_MINOR_VER}"
+	export svnurl="https://svn.osgeo.org/postgis/branches/${POSTGIS_MINOR_VER}"
 else
 	#tagged version -- official release
 	export POSTGIS_SRC=${PROJECTS}/postgis/tags/${POSTGIS_MINOR_VER}.${POSTGIS_MICRO_VERSION}
-	export svnurl="http://svn.osgeo.org/postgis/tags/${POSTGIS_MINOR_VER}.${POSTGIS_MICRO_VERSION}"
+	export svnurl="https://svn.osgeo.org/postgis/tags/${POSTGIS_MINOR_VER}.${POSTGIS_MICRO_VERSION}"
 fi;
-if [[ "$POSTGIS_MINOR_VER"  == 2.3 ]] ; then
-	export svnurl="http://svn.osgeo.org/postgis/trunk"
+if [[ "$reference"  == *trunk* ]] ; then
+	export svnurl="https://svn.osgeo.org/postgis/trunk"
 fi;
 #POSTGIS_SVN_REVISION=will_be_passed_in_by_bot
@@ -97,6 +103,7 @@
 #cp ${PGPATHEDB}/bin/libiconv2.dll  $outdir/bin/postgisgui
 cp ${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin/libicon*.dll $outdir/bin/postgisgui
 cp ${PGPATHEDB}/bin/libintl*.dll $outdir/bin/postgisgui
 cp ${PGPATHEDB}/bin/ssleay32.dll $outdir/bin/postgisgui
 cp ${PGPATHEDB}/bin/libeay32.dll $outdir/bin/postgisgui
@@ -119,6 +126,9 @@
 cp ${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
 cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
+#for protobuf
+cp ${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin/libprotobuf-c-*.dll $outdir/bin
 echo "POSTGIS: ${POSTGIS_MINOR_VER} r${POSTGIS_SVN_REVISION} http://postgis.net/source" > $verfile
@@ -136,7 +146,6 @@
 	## only copy cgal and sfcgal stuff if sfcgal is packaged
-	export CGAL_VER=4.6.1
 	export BOOST_VER=1.59.0
 	export BOOST_VER_WU=1_59_0
 	export GMP_VER=5.1.2
@@ -151,6 +160,9 @@
 	# cp -p ${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
 	# cp -p ${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/*.dll $outdir/bin/postgisgui
 fi;
+echo "PROTOBUF VERSION: ${PROTOBUF_VER} https://github.com/google/protobuf" >> $verfile
+echo "PROTOBUF-C VERSION: ${PROTOBUFC_VER} https://github.com/protobuf-c/protobuf-c"  >> $verfile
 #cp ${MINGPROJECTS}/libxml/rel-libxml2-2.7.8w${OS_BUILD}/bin/*.dll  $outdir/bin/
 cp ${PGPATHEDB}/bin/libxml2-2.dll   $outdir/bin/
@@ -186,7 +198,9 @@
 #cp topology/README* ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 #cp utils/* ${RELDIR}/${RELVERDIR}/utils
 #cp extras/* ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}/extras
-cp -r extensions/*/sql/* ${RELDIR}/${RELVERDIR}/share/extension
+cp ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension
+cp ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}next.sql ${RELDIR}/${RELVERDIR}/share/extension
+cp ${PGPATH}/share/extension/address_standardizer*${POSTGIS_MICRO_VER}.sql ${RELDIR}/${RELVERDIR}/share/extension
 cp -r extensions/*/*.control ${RELDIR}/${RELVERDIR}/share/extension
 cp -r extensions/*/*.dll ${RELDIR}/${RELVERDIR}/lib #only address_standardizer in theory has this
 #cp extensions/postgis_topology/sql/* ${RELDIR}/${RELVERDIR}/share/extension
Modified: branches/2.3/ci/winnie/regress_postgis.sh
--- branches/2.3/ci/winnie/regress_postgis.sh	2018-02-22 19:44:06 UTC (rev 16410)
+++ branches/2.3/ci/winnie/regress_postgis.sh	2018-02-22 22:22:10 UTC (rev 16411)
@@ -1,16 +1,15 @@
 #!/bin/bash
 set -e
-#winnie passed in variables
-#export GCC_TYPE=gcc48
-#export PG_VER=9.3
-#export PROJSO=libproj-0.dll
-#export POSTGIS_MAJOR_VERSION=2
-#export POSTGIS_MINOR_VERSION=2
-#export POSTGIS_MICRO_VERSION=0dev
 export PATHOLD=$PATH
@@ -54,6 +53,11 @@
 #PATH="${MINGPROJECTS}/gettext/rel-gettext-0.18.1/bin:${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtk/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}/bin:${PATH}"
 PATH="${MINGPROJECTS}/xsltproc:${MINGPROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/lib:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/include:${MINGPROJECTS}/rel-libiconv-1.13.1w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PATH}"
+#add protobuf
+export PKG_CONFIG_PATH=${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig;
 echo WORKSPACE IS $WORKSPACE
@@ -81,15 +85,14 @@
-	BOOST_VER=1.59.0
-	export BOOST_VER_WU=1_59_0
+	export CGAL_VER=4.11
+	BOOST_VER=1.53.0
+	#BOOST_VER_WU=1_49_0
+	export BOOST_VER_WU=1_53_0
-	#this is a major cludge but only building with pcre support if SFCGAL is built - can't figure out how to do this without passing PCRE
-	#TODO: turn back on topology regression testing once topology issues resolved
@@ -99,10 +102,15 @@
-  --with-pcredir=${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}  --without-interrupt-tests
+else
@@ -109,32 +117,17 @@
-else
-  --with-gettext=no
 fi;
 make clean
-fi;
@@ -152,17 +145,19 @@
  cp topology/*.dll ${PGPATHEDB}/lib
  cp postgis/postgis*.dll ${PGPATHEDB}/lib
  cp raster/rt_pg/rtpostgis-*.dll ${PGPATHEDB}/lib
- cp -r extensions/*/sql/* ${PGPATHEDB}/share/extension
+ cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}.sql ${PGPATHEDB}/share/extension
+ cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}next.sql ${PGPATHEDB}/share/extension
+ cp -r ${PGPATH}/share/extension/address_standardizer*${POSTGIS_MICRO_VER}.sql ${PGPATHEDB}/share/extension
  cp -r extensions/*/*.control ${PGPATHEDB}/share/extension
  cp -r extensions/*/*.dll ${PGPATHEDB}/lib
  make check RUNTESTFLAGS="--extension -v"
  ##test address standardizer
  cd ${POSTGIS_SRC}
  cd extensions/address_standardizer
  make installcheck
  ##test tiger geocoder
  cd ${POSTGIS_SRC}
  cd extensions/postgis_tiger_geocoder
