[postgis-tickets] r16416 - jsonb type is only available since PostgreSQL 9.4.0
Sandro Santilli
strk at kbt.io
Sat Feb 24 08:21:39 PST 2018
Author: strk
Date: 2018-02-24 08:21:38 -0800 (Sat, 24 Feb 2018)
New Revision: 16416
trunk/postgis/postgis.sql.in
Closes #4028 (thanks Dronie for finding out)
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2018-02-23 21:54:22 UTC (rev 16415)
+++ trunk/postgis/postgis.sql.in 2018-02-24 16:21:38 UTC (rev 16416)
@@ -4310,11 +4310,13 @@
AS 'SELECT @extschema at .ST_GeomFromGeoJson($1::text)'
LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
+#if POSTGIS_PGSQL_VERSION >= 94
-- Availability: 2.5.0
CREATE OR REPLACE FUNCTION ST_GeomFromGeoJson(jsonb)
RETURNS geometry
+#endif
-- Availability: 2.0.0
CREATE OR REPLACE FUNCTION postgis_libjson_version()
