[postgis-tickets] r16419 - Use more precise bounds when testing overlap of temporal ranges.
Paul Ramsey
pramsey at cleverelephant.ca
Mon Feb 26 10:19:42 PST 2018
Author: pramsey
Date: 2018-02-26 10:19:42 -0800 (Mon, 26 Feb 2018)
New Revision: 16419
trunk/liblwgeom/lwlinearreferencing.c
Fixes #4025
Modified: trunk/liblwgeom/lwlinearreferencing.c
--- trunk/liblwgeom/lwlinearreferencing.c 2018-02-26 17:55:03 UTC (rev 16418)
+++ trunk/liblwgeom/lwlinearreferencing.c 2018-02-26 18:19:42 UTC (rev 16419)
@@ -1072,7 +1072,7 @@
LWLINE *l1, *l2;
int i;
- const GBOX *gbox1, *gbox2;
+ GBOX gbox1, gbox2;
double tmin, tmax;
double *mvals;
int nmvals = 0;
@@ -1100,20 +1100,19 @@
return -1;
- /* WARNING: these ranges may be wider than real ones */
- gbox1 = lwgeom_get_bbox(g1);
- gbox2 = lwgeom_get_bbox(g2);
+ /* We use lwgeom_calculate_gbox() instead of lwgeom_get_gbox() */
+ /* because we cannot afford the float rounding inaccuracy when */
+ /* we compare the ranges for overlap below */
+ lwgeom_calculate_gbox(g1, &gbox1);
+ lwgeom_calculate_gbox(g2, &gbox2);
- assert(gbox1); /* or the npoints check above would have failed */
- assert(gbox2); /* or the npoints check above would have failed */
* Find overlapping M range
* WARNING: may be larger than the real one
- tmin = FP_MAX(gbox1->mmin, gbox2->mmin);
- tmax = FP_MIN(gbox1->mmax, gbox2->mmax);
+ tmin = FP_MAX(gbox1.mmin, gbox2.mmin);
+ tmax = FP_MIN(gbox1.mmax, gbox2.mmax);
if ( tmax < tmin )
