[postgis-tickets] r16431 - Add ST_Buffer side=arg enhancement not to the docs.
Regina Obe
lr at pcorp.us
Tue Feb 27 02:53:35 PST 2018
Author: robe
Date: 2018-02-27 02:53:34 -0800 (Tue, 27 Feb 2018)
New Revision: 16431
trunk/doc/reference_processing.xml
References #3989
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2018-02-26 20:27:24 UTC (rev 16430)
+++ trunk/doc/reference_processing.xml 2018-02-27 10:53:34 UTC (rev 16431)
@@ -70,6 +70,7 @@
fits the bounding box of the geography object (favoring UTM, Lambert Azimuthal Equal Area (LAEA) north/south pole, and falling back on mercator in worst case scenario) and then buffers in that planar spatial ref and retransforms back to WGS84 geography.</para></note>
<para><inlinegraphic fileref="images/warning.png" />
For geography this may not behave as expected if object is sufficiently large that it falls between two UTM zones or crosses the dateline</para>
+ <para>Enhanced: 2.5.0 - ST_Buffer geometry support was enhanced to allow for side buffering specification <code>side=both|left|right</code>.</para>
<para>Availability: 1.5 - ST_Buffer was enhanced to support different endcaps and join types. These are useful for example to convert road linestrings
into polygon roads with flat or square edges instead of rounded edges. Thin wrapper for geography was added. - requires GEOS >= 3.2 to take advantage of advanced geometry functionality.
</para>
