[postgis-tickets] [PostGIS] #4031: ST_CurveToLine with small tolerance sometimes causes invalid memory alloc request size
trac at osgeo.org
Wed Feb 28 04:30:08 PST 2018
request size
Reporter: kkgeodk | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.4.4
Component: postgis | Version: 2.2.x
Keywords: ST_CurveToLine |
ST_CurveToLine([geometry], 0.01, 1, 1) causes ERROR: invalid memory alloc
request size 1073741824\\
Same ERROR with:\\
ST_CurveToLine([geometry], 0.05, 1, 1)\\
ST_CurveToLine([geometry], 0.1, 1, 1)\\
ST_CurveToLine([geometry], 1, 1, 1)\\
With ST_CurveToLine([geometry], 32, 0, 1), this ERROR cannot be
reproduced.\\
Shared memory segment in bytes has been increased. This did not solve our
issue:\\
# Maximum size of a single shared memory segment in bytes\\
#kernel.shmmax = 33554432\\
kernel.shmmax = 3055017984\\
Find test data attached. object t_id= 1727145 seems to be the issue.
System:\\
Ubuntu 14.04.5 LTS\\
PostgreSQL 9.3\\
PostGIS 2.2 with ST_CurveToLine backport from
https://github.com/strk/postgis/tree/svn-2.2-curve-to-line-extended\\
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4031>
