[postgis-tickets] [PostGIS] #4031: ST_CurveToLine with small tolerance sometimes causes invalid memory alloc request size
PostGIS trac at osgeo.org
Wed Feb 28 05:19:28 PST 2018
request size
  Reporter:  kkgeodk  |      Owner:  strk
      Type:  defect   |     Status:  assigned
  Priority:  medium   |  Milestone:  PostGIS 2.4.4
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:  ST_CurveToLine
Comment (by strk):
 The smaller error tolerance, the higher number of segments will be
 required to approximate the line. It may of course be too many.
 How do you suggest to deal with this ?
 Similar issue exists with ST_Segmentize (for example).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4031#comment:1>
