[postgis-tickets] [PostGIS] #3975: ST_Transform references spatial_ref_sys without schema
trac at osgeo.org
Tue Jan 9 08:14:41 PST 2018
Reporter: javitonino | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.3
Component: postgis | Version: 2.4.x
Keywords: |
When trying to pg_restore a dump with some index that uses ST_Transform
({{{CREATE INDEX ON schema.tab (st_transform(geom,3857)); }}}) you end up
getting errors that {{{spatial_ref_sys}}} does not exists.
Steps to reproduce:
psql -U postgres
create database db;
\c db
create extension postgis;
create schema sc;
create table sc.tab(geom geometry);
create index on sc.tab (st_transform(geom,3857));
insert into sc.tab values (st_setsrid(st_point(0,0), 4326));
\q
pg_dump -U postgres db -Fc > dump
dropdb -U postgres db
createdb -U postgres db
pg_restore -U postgres -d db dump
pg_restore: [archiver (db)] Error from TOC entry 3435; 1259 15521376 INDEX
tab_st_transform_idx1 postgres
pg_restore: [archiver (db)] could not execute query: ERROR: relation
"spatial_ref_sys" does not exist
LINE 1: SELECT proj4text FROM spatial_ref_sys WHERE srid = 4326 LIMI...
I think the issue is that the SQL query is run from C code, where it has
not been qualified with @extschema@ like the rest of the code since 2.3,
causing the query to fail when run from pg_restore (which sets the
search_path to the schema of the objects it's restoring).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3975>
