[postgis-tickets] [PostGIS] #3975: ST_Transform references spatial_ref_sys without schema
PostGIS trac at osgeo.org
Thu Jan 11 05:49:27 PST 2018
  Reporter:  javitonino  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS 2.4.3
 Component:  postgis     |    Version:  2.4.x
Resolution:              |   Keywords:
Comment (by pramsey):
 Well, we cannot use the @extschema@ trick here, as it's inside the C code.
 I wonder if we can use the fact that we're being executed with a function
 to find out what schema that function is installed in. That could end up
 being a lot of overhead on the transform code to look that up on every
 call, but it's the only way I can see to keep the extension relocatable.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3975#comment:1>
