[postgis-tickets] [PostGIS] #3952: ST_Transform fails in parallel mode
PostGIS trac at osgeo.org
Wed Jan 10 06:02:43 PST 2018
  Reporter:  pramsey  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.4.3
 Component:  postgis  |    Version:  2.4.x
Resolution:           |   Keywords:
Comment (by pramsey):
 Well, I think it makes sense to make that change in principle, since
 ST_Transform is not immutable, but it is stable.
 However, for the problem at hand, it turns out we can probably dodge it
 with just the change in r16248. I still have to test to confirm, but from
 reading the pgsql code and docs, it should be sufficient to dodge the
 error case.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3952#comment:4>
