[postgis-tickets] [PostGIS] #3952: ST_Transform fails in parallel mode
trac at osgeo.org
Wed Jan 10 07:07:34 PST 2018
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.3
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by pramsey):
This is more specific than I thought. Using our Carto pgsql branch, which
has a backport of the pg11 parallel "create table as" support in it, and
changing to SPI_execute, causes a crash condition. Using generic pg10,
there is no parallel mode, and no crash condition.
Running the ST_Transform query without the "create table as" part causes
**no problems** even when a parallel plan is used. So the problem is
(currently) specific to the carto branch, but **might also** be something
that is an issue in pg11 since that's where we pulled the "create table
as" support from.
Next test: on pg11 is this use case (parallel "create table as")
problematic.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3952#comment:5>
