[postgis-tickets] [PostGIS] #3952: ST_Transform fails in parallel mode
trac at osgeo.org
Wed Jan 10 08:31:31 PST 2018
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.3
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by pramsey):
OK, so the problem has nothing to do w/ ST_Transform, and the fix in
r16248 is still worth applying "on the merits", since, per the pgsql
documentation, marking the SPI routine as read_only has the effect of
rendering functions "truly stable", so we can also mark st_transform as
stable and feel good about it.
I can crash our carto branch of pgsql just be forcing it into a parallel
"create table as", so the problem has nothing to do w/ postgis and is
contained in our own hackery.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3952#comment:6>
