[postgis-tickets] r16252 - Fix generation of postgis_topology.control
Sandro Santilli
strk at kbt.io
Wed Jan 10 09:57:39 PST 2018
Author: strk
Date: 2018-01-10 21:57:38 -0800 (Wed, 10 Jan 2018)
New Revision: 16252
trunk/extensions/postgis_topology/Makefile.in
trunk/extensions/postgis_topology/postgis_topology.control.in
Modified: trunk/extensions/postgis_topology/Makefile.in
--- trunk/extensions/postgis_topology/Makefile.in 2018-01-10 19:27:48 UTC (rev 16251)
+++ trunk/extensions/postgis_topology/Makefile.in 2018-01-11 05:57:38 UTC (rev 16252)
@@ -44,6 +44,11 @@
all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql
+$(EXTENSION).control: $(EXTENSION).control.in Makefile
+ cat $< \
+ | sed -e 's|@EXTVERSION@|$(EXTVERSION)|g' \
sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql
mkdir -p sql
cp $< $@
Modified: trunk/extensions/postgis_topology/postgis_topology.control.in
--- trunk/extensions/postgis_topology/postgis_topology.control.in 2018-01-10 19:27:48 UTC (rev 16251)
+++ trunk/extensions/postgis_topology/postgis_topology.control.in 2018-01-11 05:57:38 UTC (rev 16252)
@@ -1,6 +1,6 @@
# postgis topology extension
comment = 'PostGIS topology spatial types and functions'
-default_version = '@POSTGIS_LIB_VERSION@'
+default_version = '@EXTVERSION@'
relocatable = false
schema = topology
requires = postgis
