[postgis-tickets] r16253 - Refactor sfcgal extension script to use generic include
Sandro Santilli
strk at kbt.io
Wed Jan 10 09:57:47 PST 2018
Author: strk
Date: 2018-01-10 21:57:47 -0800 (Wed, 10 Jan 2018)
New Revision: 16253
trunk/extensions/postgis_sfcgal/Makefile.in
trunk/extensions/postgis_sfcgal/postgis_sfcgal.control.in
This is an attempt to fix upgrade test on Debbie, saying:
ERROR: extension "postgis_sfcgal" does not exist
ref: https://debbie.postgis.net/job/PostGIS_Regress/8259/console
Modified: trunk/extensions/postgis_sfcgal/Makefile.in
--- trunk/extensions/postgis_sfcgal/Makefile.in 2018-01-11 05:57:38 UTC (rev 16252)
+++ trunk/extensions/postgis_sfcgal/Makefile.in 2018-01-11 05:57:47 UTC (rev 16253)
@@ -22,15 +22,28 @@
$(GREP) "[a-zA-Z]" | \
$(PERL) -pe 's/(\d+[a-zA-Z]+)\d*/\1/'
-DATA = $(filter-out $(wildcard sql/*--*.sql),$(wildcard sql/*.sql))
+DATA_built = \
+ $(EXTENSION).control \
+ sql/$(EXTENSION)--$(EXTVERSION).sql \
+ sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql \
+ $(NULL)
+# Scripts making up the extension minor upgrade file
+# NOTE: order matters
+EXTENSION_UPGRADE_SCRIPTS = \
+ sql_bits/sfcgal_upgrade_minor.sql
PG_CONFIG = @PG_CONFIG@
SQL_BITS = $(wildcard sql_bits/*.sql)
EXTRA_CLEAN += sql/*.sql ${SQL_BITS}
+all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql
-all: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql sql_minor_upgrade
+$(EXTENSION).control: $(EXTENSION).control.in Makefile
+ cat $< \
+ | sed -e 's|@EXTVERSION@|$(EXTVERSION)|g' \
sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql
mkdir -p sql
@@ -75,13 +88,10 @@
printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
cat $^ >> $@
-sql_minor_upgrade: sql_bits/sfcgal_upgrade_minor.sql
- for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
- cat $< > sql/$(EXTENSION)--$$OLD_VERSION--$(EXTVERSION).sql; \
- done
+sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS)
+ cat $(EXTENSION_UPGRADE_SCRIPTS) > $@
-DATA = $(wildcard sql/*--*.sql)
-EXTRA_CLEAN += sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql
+include ../upgrade-paths-rules.mk
distclean: clean
rm Makefile
Modified: trunk/extensions/postgis_sfcgal/postgis_sfcgal.control.in
--- trunk/extensions/postgis_sfcgal/postgis_sfcgal.control.in 2018-01-11 05:57:38 UTC (rev 16252)
+++ trunk/extensions/postgis_sfcgal/postgis_sfcgal.control.in 2018-01-11 05:57:47 UTC (rev 16253)
@@ -1,5 +1,5 @@
# postgis topology extension
comment = 'PostGIS SFCGAL functions'
-default_version = '@POSTGIS_LIB_VERSION@'
+default_version = '@EXTVERSION@'
relocatable = true
requires = postgis
