[postgis-tickets] [PostGIS] #3981: unpackaged--2.5.0dev upgrade fails to find sfcgal
trac at osgeo.org
Wed Jan 10 22:36:26 PST 2018
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.3
Component: postgis | Version: 2.4.x
Keywords: |
See https://debbie.postgis.net/job/PostGIS_Regress/8271/console
Upgrading PostGIS in 'postgis_reg' using: CREATE EXTENSION postgis VERSION
'2.5.0dev' FROM unpackaged
failed (Error encountered creating EXTENSION POSTGIS_SFCGAL:
/var/lib/jenkins/workspace/postgis/tmp/2_5_pg9.5w64/regress_log)
WARNING: 'postgis.backend' is already set and cannot be changed until you
reconnect
CONTEXT: SQL statement "SELECT postgis_lib_version()"
PL/pgSQL function postgis_major_version_check() line 21 at SQL statement
WARNING: 'postgis.gdal_datapath' is already set and cannot be changed
until you reconnect
postgis_raster_lib_version()"
WARNING: 'postgis.gdal_enabled_drivers' is already set and cannot be
changed until you reconnect
WARNING: 'postgis.enable_outdb_rasters' is already set and cannot be
CREATE EXTENSION
ERROR: extension "postgis_sfcgal" does not exist
Makefile:303: recipe for target 'check' failed
make: *** [check] Error 1
make: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/2.5/regress'
FAIL: upgrade unpackaged--2.5.0dev
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3981>
